826 to 524 Engine Swap - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 02-10-2019, 11:21 PM Thread Starter
I'm considering taking the engine from my 826 (38150) and putting it on my 524 (31624). Is there anything I should be particularly concerned with in doing so?
creeve4 is offline
post #2 of 10 Old 02-11-2019, 10:06 AM
Likes (Received): 1379
What is wrong with the 8-26?????
post #3 of 10 Old 02-11-2019, 12:23 PM
Thanks (Received): 212
Likes (Received): 767
The mounting holes on the 8 hp will have to be moved back some to fit the 5 hp.
cranman is offline
post #4 of 10 Old 02-11-2019, 01:59 PM Thread Starter
It works well, but my 524 is in better mechanical shape and I like the controls on it better.
creeve4 is offline
post #5 of 10 Old 02-11-2019, 02:14 PM
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 277
Likes (Received): 172
I thought the Tecumsehs from 4hp to 8hp had the same engine mount bolt pattern? Is this not correct? Or are you saying the entire engine has to move a bit on the blower frame?
Thanks.
Paul
paulm12 is online now
post #6 of 10 Old 02-11-2019, 02:37 PM Thread Starter
My 826 has a B&S engine.
creeve4 is offline
post #7 of 10 Old 02-11-2019, 04:16 PM
Likes (Given): 1882
Likes (Received): 663
my old 38150 826 had a B&S motor also
post #8 of 10 Old 02-11-2019, 04:53 PM
Thanks (Given): 63
Likes (Given): 277
Hmm. This is what happens when I think. thanks all.
edit: the reason I asked is because I am looking at used engine options for my Toro 521 and 421, both are Tec's.
Paul
post #9 of 10 Old 02-11-2019, 04:56 PM
Thanks.
up to 7 hp is the small block Tec's 8 and up are the medium frame
cranman is offline
post #10 of 10 Old 02-11-2019, 05:01 PM
I'm thinking you just got to check out the crank height on both engines and the bolt patterns, and placement on the frame, and the crank diameter so you can use the right pulley.....might be more work then it's worth. If the 5 hp engine is a Tecumseh...just bolt on a Predator.
cranman is offline
Similar Threads
LCT and Lifan engine swap question Dauntae Snowblower Repairs and Maintenance Forum 1 01-02-2018 09:40 PM
Toro 421, Predator engine swap? frankjc Toro Snowblowers 20 01-08-2016 10:26 AM
Toro 826OE engine swap bosco659 Toro Snowblowers 5 03-10-2014 06:15 AM
Engine swap RocketPower Ariens Snowblowers 27 02-27-2013 06:34 AM
Engine swap swampjeff General Snowblower Discussion 4 01-01-2011 01:27 PM
