8/32 toro levers - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-15-2019, 08:53 PM Thread Starter
8/32 toro levers
picked up a Toro 8/32 and was wondering what the levers are for on the handlebar cause they have been disconnected probl one for cut-off on left but right side ?? ther seems to have no clutch to stop drive to change shift.! THKS
Blizzard440 is offline
post #2 of 5 Old 02-15-2019, 10:17 PM
Thanks (Received): 25
Likes (Received): 31
Redundancy. You had to squeeze either the left or the right while the auger or drive was engaged so that if you fell the machine would shut off. A lot of people taped them down or removed them.
SnoThro is offline
post #3 of 5 Old 02-16-2019, 10:55 AM Thread Starter
ok Thks so it dosn,t fall neutral like newer blowers to change gears or stop auger while running.
post #4 of 5 Old 02-16-2019, 11:20 AM
Likes (Received): 1379
They are called DEADMAN SWITCHES. you have to keep 1 paw locked down on it. in order to do anything. If you are tooling along down a big open highway and slip and fall the ENGINE is now DEAD ON ARRIVAL. But if the contacts on the handle bars are shot or gone with the Schwinn those parts are now all NLA!!!!!!!!!!!. Had them on "SR" when I raised him up from THE DEAD. Have no clue if they still worked or not so I just ripped them off of him. As long as you have 1 paw clamped down on them. you can double clutch shifting gears till the cows come home to be milked.
post #5 of 5 Old 02-16-2019, 07:45 PM Thread Starter
THKS for the info.!
Similar Threads
Toro 8/32 Blower friction disq adjustement Help.!! Blizzard440 Toro Snowblowers 2 01-24-2017 07:50 PM
Toro POWER MAX 726TE [email protected] Snowblowers and Snowblower Parts Wanted 5 02-05-2016 08:58 AM
Toro vs. Simplicity in the $1500 segment gmazet General Snowblower Discussion 35 01-24-2016 12:05 PM
TORO 8/32 part needed JerryD Snowblowers and Snowblower Parts Wanted 7 05-26-2014 07:11 PM
