Contractor uses the 724 QXE in deep snow - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 02-16-2019, 02:34 PM Thread Starter
Likes (Received): 12
carterlake is offline
Post Thanks / Like - 0 Thanks, 4 Likes, 0 Dislikes
post #2 of 11 Old 02-16-2019, 03:05 PM
Thanks (Given): 79
Thanks (Received): 83
Likes (Given): 329
Likes (Received): 362
for the light stuff there is nothing faster
1989 John Deere 1032
tdipaul is offline
post #3 of 11 Old 02-16-2019, 04:31 PM
Thanks (Received): 212
Likes (Received): 767
first I've ever seen .....great for a single stage...very impressive.
cranman is offline
Likes micah68kj liked this post
post #4 of 11 Old 02-16-2019, 07:15 PM
Thanks (Given): 173
Likes (Given): 456
Likes (Received): 1032
Light stuff??? Did you watch him moving all that EOD?
post #5 of 11 Old 02-16-2019, 07:46 PM
Thanks (Given): 59
Thanks (Received): 72
Likes (Given): 58
Likes (Received): 183
single stage, snow cleared right down to the pavement and was able to handle the chunky iced up eod, sweet
MY VIDS ON FIXIN HER UP
vinnycom is offline
post #6 of 11 Old 02-17-2019, 08:10 AM
Thanks (Given): 172
Thanks (Received): 337
Likes (Given): 476
Likes (Received): 836
That is very cool. It did an impressive job, even at the EOD. He was taking narrower cuts for the EOD, but that's very reasonable, and it *was* handling it, which is the important parts.
From pics on Toro's site, the setup looks a bit different than a typical SS. The auger is steel, and seems to only have a rubber paddle at the center. So I assume that it's not really clearing down to the pavement the same way that a SS usually would, since most of the auger can't be allowed to touch the ground. But, it has a spring-loaded plastic scraper bar, which should help minimize leaving a film of snow behind.
I'd expect the spring-loaded scraper bar would probably be pretty effective for untouched snow, like this. If you've driven over it, and packed the snow down, I'd imagine the scraper bar would be more likely to ride up over the packed snow, but I'm just guessing.
I sure wouldn't mind adding an 824 QXE to my collection It would probably make a really nice single-machine setup. Though a SS and a 2-stage still seems like a nice combination. Of course it does require more space and maintenance.
https://www.toro.com/snowmaster
post #7 of 11 Old 02-17-2019, 08:23 AM
Thanks (Given): 79
Likes (Given): 329
I wonder if Toro will ever make a 32" or 36" wide version with 420CC and dual serpentine style auger drive belts.
The operator could have utilized the extra width throughout most of the video.
Ok so for the EoD maybe not, but everywhere else, yes (like at 8:50).
Sign me up.
tdipaul is offline
post #8 of 11 Old 02-17-2019, 10:19 AM Thread Starter
So finally got a decent snowfall. 6" light stuff with over 12" at EoD and drifts. Did mine and both neighbors driveways and sidewalks (one is a corner double lot). Took 45 minutes.
724 QXE really is the best of both worlds.
More snow expected on Tuesday/Wednesday.
post #9 of 11 Old 02-17-2019, 11:25 AM
Thanks (Given): 24
Thanks (Received): 41
Likes (Given): 45
Likes (Received): 255
That's impressive.
tlshawks is offline
post #10 of 11 Old 02-17-2019, 12:04 PM
Thanks (Given): 172
Likes (Given): 476
Very nice! Let us know how it does. Is that your video, or something you found?
I'd love to try one of these at some point. I just got my first decent SS, so I'm looking forward to more chances to see what it can handle. For the 4" we got this week (first test of it), it took half the time, vs my 2-stage in the previous storm, which was very similar snow.
I'm sure the SnowMasters are even more capable than my SS (and the joystick chute control seems even nicer than my Quick Shoot). I admit I'd be a bit nervous about having one as my only machine. I like being able to wait until the end of an 18"+ wet/heavy storm, and clear it all at once, and not worry about whether the machine will be overwhelmed. Not to say that these can't do that, but with the higher augers speed, they can't put as much torque into the augers, which must limit them somewhat for chewing through solid EOD. But those storm sizes for us are rare. Even in a big storm, most of the time I could clear it in stages during the storm, if needed. So even if there were some limits, they'd probably be manageable.
How is traction, when pushing into heavy stuff? My 2-stage is 300 lbs, with chains, and I can still have traction issues (inclined driveway doesn't help). These are 120-130 lbs, and smaller wheels, but the same width as my 2-stage. It makes me wonder if they struggle with wheelspin against heavy stuff. Are both wheels locked together when it's driving, giving you the same traction as a solid axle? Or can you spin just one wheel, like with a differential?
Can you re-aim the joystick left/right while actually blowing snow? My Quick Shoot kind of bound up while there was snow coming out, so it was easier to stop for a sec, re-aim, and then start blowing again. Toro said that's how you're supposed to use it. But it seems like the joystick systems can be re-aimed while there's snow coming out.
Similar Threads
Upgrading your snowblower lights to LED lights superedge88 General Snowblower Discussion 1364 02-23-2020 03:03 PM
Snow Blower run time? sunlight99 General Snowblower Discussion 29 10-21-2017 07:51 AM
about to buy a new snowblower cronin_burger New Member Introductions 20 10-09-2017 08:22 AM
Hinowa tracked tractor 2 stage snow caster from Italy leonz General Snowblower Discussion 0 07-22-2017 08:19 PM
Snowblowing Rules of Thumb SMFCPACFP General Snowblower Discussion 3 02-10-2012 08:57 AM
