Old Toro 826 traction drive problem - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 02-18-2019, 01:08 PM Thread Starter
Hi everyone,
I have a Toro 826 that is new to me this year. Model #38060. I'm pretty sure this model is from the late 70's or early 80's.
I'm having an issue where the drive is only working on #3. There is no forward movement at all when on #1 or #2.
I opened it up to see what the problem is. It seems like there is too much play in the linkage between the shifter and the friction wheel, so that when I try to shift to #1 or #2, the wheel just slides over to the middle of the drive disk as soon as it makes contact. How much play is there supposed to be in this linkage? I assume that it should be relatively solid with not much side to side movement of the friction wheel when it is in gear? Is there supposed to be a spring or something to take out the play in the linkage?
Assuming that the linkage parts are just worn out and need replacement, where does everyone here buy their parts? I checked on partstree.com and the parts I need are not available.
Thank you!
sjthuss is offline
post #2 of 17 Old 02-18-2019, 10:48 PM
Thanks (Received): 25
Likes (Received): 31
Going from memory the most common problem is the shift rod getting bent a bit. If the friction disc is worn enough and not gripping well make sure that rod is good and straight then I think you want to loosen the jam nut and lengthen it. Just keep adjusting until you cant move the wheels anymore under your own power. There should be a couple beefy springs attached to either side of the arm assembly to hold the disc against the plate when its engaged.
Everything should be tight as far as side to side wiggle is concerned. If there is significant play in the bushings and bearings then that could also cause a problem. For springs and bushings, if NLA, try a source like Mcmaster Carr or MSC.
SnoThro is offline
post #3 of 17 Old 02-19-2019, 08:55 AM
Thanks (Received): 379
Likes (Received): 1377
What does the Friction Wheel look like??????????? ALOHA From The Paradise City.
post #4 of 17 Old 02-19-2019, 07:09 PM Thread Starter
Thanks for the replies,
The rubber friction wheel looks like it's in really good shape actually. I think it must have been replaced at some point in the last few years because it looks relatively new.
The problem seems to be that there is so much play/slop in the shifter linkage. For example, when the shifter is in neutral (so the wheel is not touching the disc), I can easily move the wheel left and right by at least 3 inches. What happens when I try to put it in gear is that as soon as the wheel touches the disc, the rotation of the disc pulls the wheel to the left until it's riding right in the centre of the disc and there is no forward motion anymore. 3rd still works somewhat because the wheel still pulls to the left, but it runs out of slack in the linkage and ends up roughly where #2 should be.
Does this make sense? I'll try to snap some pictures once I can get out to the garage again.
sjthuss is offline
post #5 of 17 Old 02-20-2019, 02:36 PM
Likes (Received): 280
Here's what a new disc should look like https://www.partstree.com/parts/toro/parts/40-8170/
otherwise I'd say make the the rod is not bent and that it is riding in the correct postion relative to the disc position... you may need to adjust the length.
Look at the control rod spring part #69 here.... https://www.partstree.com/parts/toro...ndle-assembly/
post #6 of 17 Old 02-20-2019, 03:20 PM
Thanks (Given): 587
Thanks (Received): 765
Likes (Given): 4344
Likes (Received): 1731
to SBF sjthuss
Maybe a photo or two might be helpful.
post #7 of 17 Old 02-20-2019, 03:32 PM
groomerz's Avatar
Thanks (Given): 11
Thanks (Received): 22
Likes (Received): 46
Thumbs up
to SBF sjthuss
I second the photo or video . My crystal ball is cloudy. Put it in the service position with belly pan off and show us video or pictures of linkage asn you will get real help here.
groomerz is offline
post #8 of 17 Old 02-20-2019, 03:48 PM
Jackmels's Avatar
Thanks (Received): 194
Likes (Received): 814
Needs A Stronger or New Spring that Tensions the Friction Wheel when in Drive Position
Jackmels is offline
post #9 of 17 Old 02-20-2019, 04:34 PM
Well at least those are not NLA.
post #10 of 17 Old 02-20-2019, 05:56 PM
Is just the carrier assembly moving (disc and piece disc is bolted to) or is the whole shaft assembly moving left and right?
SnoThro is offline
Similar Threads
Toro 824 Model: 38080 (1990) Traction Assembly Issue ts8169 Toro Snowblowers 21 11-19-2019 03:43 PM
Yardman drive problem micronta Yard-Man Snowblowers 6 11-12-2017 10:58 PM
2006 24" 9hp traction problem danmp Craftsman Snowblowers 4 12-15-2016 10:31 AM
My 1978 Yardman Snowbird 31600-9: Problem #2, fricton wheel/aluminum drive plate ztnoo Snowblower Repairs and Maintenance Forum 7 12-05-2015 10:36 AM
Ariens Pro 32 Automatic Turn problem and drive slipping problems steveg_nh Ariens Snowblowers 14 02-11-2015 06:56 PM
