Help Me Get a 1974 Toro Running - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 02-23-2019, 10:21 AM Thread Starter
I tried to film my latest attempt. Sorry for the shaky video.
https://youtu.be/KGzCxQfwghg
Briggs & Stratton model 31263. Spark plug appears to be ok. Looking for any suggestions if you can diagnose anything from this video. Appreciate the help.
Ocean_Playground is offline
post #2 of 21 Old 02-23-2019, 10:42 AM
Thanks (Received): 212
Likes (Received): 767
The only thing that video tells me is you have some compression. You need compression, fuel, and ignition delivered at the proper time. I'm going to guess either fuel or ignition, not timing. With that old Briggs, I would pop the recoil cover, and bolt on a modern Briggs coil....most any single cylinder will work, I use vertical shaft coils from blown up lawn tractors, ...and you can be sure of strong reliable spark. The points on those old Brigg's are a PIA. Before you get to involved , use some carb cleaner or starting fluid in the carb. If it fires your problem is fuel, if not you need spark . Even if you have spark, once you get it straightened out , I'd get rid of the points. Something else is the safety interlock on those old Toros. If those aren't working you get no spark. disconnect the kill wire from the coil and try before anything else.
cranman is offline
post #3 of 21 Old 02-23-2019, 10:48 AM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
Nice video but not complete because
How clean and free of rust is your fuel tank? Carburetor? Are you absolutely sure?
If not, disconnect the fuel line, drain the fuel bowl
Remove the spark plug
Pull the cord a few times to clear out any bad gas from the cylinder
With the spark plug removed, Ground the spark plug, pull the cord, check for spark, if not, clean the points or install a Mega Fire replacement ignition module, you can also remove the flywheel housing and clean the magnets, check for gap, check the flywheel key
Install the spark plug
Spray starting fluid in the carb, now try to start it
If it starts, put the gas line back with fresh fuel.
JLawrence08648 is offline
post #4 of 21 Old 02-23-2019, 11:00 AM
Thanks (Given): 172
Thanks (Received): 337
Likes (Given): 477
Likes (Received): 836
Good advice so far. Before messing with coils, I'd start with the suggestion of squirting some gas or starting fluid into the carb. If it will run for a few seconds on that, then you at least have a serviceable spark.
What are the two controls you were messing with on the carb in the video? The lever might be the choke. But that just needs to be in the proper position for starting (choke on, with the plate closing off the carb's intake). Flipping the choke back/forth with the engine just sitting won't do anything.
post #5 of 21 Old 02-23-2019, 01:02 PM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
In the brief shot of the control panel, the throttle was set to the rear. On my 70's 724, forward is for high throttle, and the ignition cuts when to the rear - not sure about this one. And And as others have notes, dinking the choke back and forth won't accomplish anything - it needs to be closed for start . . .
tadawson is offline
post #6 of 21 Old 02-23-2019, 05:17 PM Thread Starter
Thanks for the input. The carb is new and there is no rust in the tank. I will try with some starter fluid and follow the suggestions here on the spark plug.
In the video I was just trying to to demonstrate the position of the choke. And it was in neutral the whole time.
post #7 of 21 Old 02-23-2019, 06:00 PM
Likes (Received): 1379
For The Love of ZEUS!!!!!!!!!!! DO NOT USE THAT BLOODY FREAKING STARTER FLUID!!!!!! You could blow a hole right through that piston!!!!!!!!!!
post #8 of 21 Old 02-23-2019, 06:03 PM
THE Problem is in those safety interlock's. you are not getting any spark.
post #9 of 21 Old 02-23-2019, 06:59 PM
Thanks (Given): 26
Likes (Given): 85
OK, carb is likely questionanble (but new) third world which has never run, and the tank is clean. You said nothing about the age and condition of the fuel line, and there is always a chance the carb is bad. Ignition also, since Toro typically has an ignition kill on the carb, and if your new one didn't do that right, it may well have the ignition shut down for you . . .
tadawson is offline
post #10 of 21 Old 02-23-2019, 08:28 PM
Thanks (Given): 172
Likes (Given): 477
I don't know if maybe carb cleaner is gentler when it ignites?
I recently ordered a $1 plastic squeeze bottle that has a tube going to the bottom. We use ones like it at work. It should let me put some gas in the bottle, and give it a squeeze to squirt some gas into the carb. I'll probably use mixed 2-stroke gas, which can safely be used for a 2-stroke or a 4-stroke. It won't be more violent than normal gas, and it'll also bring a little lubrication along with it.
https://www.ebay.com/itm/250ml-500ml...72.m2749.l2649
Similar Threads
Need your help: Ariens Platinum 30 SHO or Toro Power Max HD 1028 jktbnelson General Snowblower Discussion 28 01-09-2019 10:35 AM
1974 Toro 524, new owner creeve4 Toro Snowblowers 27 11-09-2017 01:04 PM
Toro -Sounds its running out of gas michaeljohkelly Toro Snowblowers 3 12-20-2016 08:41 PM
Toro 824XL will not stay running. tripseven Toro Snowblowers 4 09-19-2011 12:20 PM
Toro 824 XL will not stay running tripseven Snowblower Repairs and Maintenance Forum 3 01-14-2011 09:39 PM
