Toro Power Max 1028 LXE clogged - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 03-05-2019, 12:01 PM Thread Starter
Question Toro Power Max 1028 LXE clogged
Hi folks!
Long time reader, first time poster
My 1028 LXE binds up in heavy wet snow.
I'm in Eastern Canada and trust me, the snow is like lead most times!!!!!
She does not stall....just stops throwing snow. From what I can see, the impeller still spins, but the augers will not turn.
I've checked out the bolts and belts...all fine, but I replaced the belts as they were showing wear.....alas, no change!
If the snow is light and dusty, she throws it a mile, but any weight or depth...nadda!
The impeller and shaft will spin manually; the augers do not
I read another thread
https://www.snowblowerforum.com/foru...-spinning.html
stuart80112 (who is not here anymore) had a great response!
I'm guessing the answer is in the gearbox......yes?
Break it to me gently boys....this girl is still learning!
Thanks in advance!
Jen L Dawe is offline
post #2 of 4 Old 03-05-2019, 11:09 PM
Thanks (Received): 25
Likes (Received): 31
Sounds like a spot on the helical gear has stripped. Impeller should never spin without the rakes unless the shear bolts are broken.
SnoThro is offline
post #3 of 4 Old 03-06-2019, 08:48 AM
Likes (Given): 68
Likes (Received): 16
Hey, Jen, where on The Rock do you live? I have relatives up there.
TORO 1028 LE with a new BRIGGS 1550 342cc engine.
guybb3 is offline
post #4 of 4 Old 03-06-2019, 10:09 AM
Thanks (Given): 172
Thanks (Received): 335
Likes (Given): 472
Likes (Received): 831
Welcome to the forum! Yeah it sounds to me like there is a problem in the auger gearbox, unfortunately. If the impeller turns, but the augers do not, and the shear bolts are interact, that is likely a failure in the gearbox.
That can likely be fixed, but is more involved & expensive.
Similar Threads
Toro Power Max 826 OXE vs Honda vs MTD Yardworks 24"/208 CC coptic General Snowblower Discussion 21 01-24-2017 07:39 AM
Toro Power Max HD 928 OE (38660) Drewfay333 General Snowblower Discussion 4 10-20-2015 09:58 AM
Toro XL824 stalls on full power tripseven Snowblower Repairs and Maintenance Forum 3 03-06-2013 11:24 PM
Toro Power Clear 180 review amped_16 Snowblower Reviews 3 01-22-2012 11:38 AM
