726 final drive sprocket groove pin? - Snowblower Forum : Snow Blower Forums
post #1 of 1 Old 03-11-2019, 01:56 PM Thread Starter
Thanks (Given): 7
The only consistent problem I have with this old machine is with the way the final drive sprocket is pinned to the shaft. It is supposed to be a solid 1/4" "groove pin" but that had sheared. (Probably why I was given the machine....)
I have been using grade 8 1/4" bolts, but these only last a few hours before shearing. I've been assuming these are at least as strong as a groove pin but maybe I'm wrong about that. I've been thinking about drilling out the shaft and sprocket for a 5/16" or 3/8" pin or bolt but that would be a bit of a pain.
Suggestions? Is this a common problem with these machines?
Thanks.
amuller is offline
Similar Threads
what do these numbers mean??? stromr Honda Snowblowers 5 02-21-2019 08:40 PM
Drive Sprocket for JD TRS32 DaHen Snowblower Repairs and Maintenance Forum 10 01-17-2018 02:34 PM
HS828 - Drive sprocket removal help - stuck 'keeper' pin gb387 Honda Snowblowers 1 11-02-2014 05:51 PM
Craftsman c950-52518-6. Drive chain jumping off axle sprocket. Why and how to fix? catalyst519 Snowblower Repairs and Maintenance Forum 2 02-18-2014 09:45 PM
Drive Chain Slips Off Sprocket nymills Snowblower Repairs and Maintenance Forum 4 01-22-2014 09:01 PM
