726 final drive sprocket groove pin? - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 03-11-2019, 02:57 PM Thread Starter
Thanks (Given): 7
The only consistent problem I have with this old machine is with the way the final drive sprocket is pinned to the shaft. It is supposed to be a solid 1/4" "groove pin" but that had sheared. (Probably why I was given the machine....) I have been using grade 8 1/4" bolts, but these only last a few hours before shearing. I've been assuming these are at least as strong as a groove pin but maybe I'm wrong about that. I've been thinking about drilling out the shaft and sprocket for a 5/16" or 3/8" pin or bolt but that would be a bit of a pain. Suggestions? Is this a common problem with these machines? Thanks.
amuller is offline
post #2 of 5 Old 03-11-2019, 05:57 PM
Thanks (Given): 169
Thanks (Received): 305
Likes (Given): 421
Likes (Received): 1012
You must have something else going on. That's one of the last things that would break. Something out of line stuck or something hanging up?
Groove pin. ... Are you meaning a roll pin?
This?
post #3 of 5 Old 03-11-2019, 10:18 PM
Thanks (Received): 25
Likes (Received): 31
Either replace the split pin that was there or try something like a Spirol pin which is essentially a split pin that's been rolled like a cigar to give it more strength. I'd only drill it if the hole is wallowed which will allows the drive play to hammer any pin or bolt until it breaks. If you do have to drill i'd go the next size up on a split or spirol pin as you'll have a lot more intermediate sizes as opposed to removing a lot of material to get a 5/16 bolt to fit.
Grade 8 and Stainless are harder and thus more likely to break than bend when put under load or hammered.
SnoThro is offline
post #4 of 5 Old 04-11-2019, 06:05 PM Thread Starter
Thanks (Given): 7
Well, I have sheared two today. I need to solve this or the machine will have to be retired.
Obviously the 1/4" grade 8 bolts aren't the answer! The hole is too close to the sprocket plate for 5/16" nuts/bolt heads.
I expect the holes in the the shaft and the sprocket hub are somewhat wallowed. Likely, enough that a 1/4" spirol pin won't stay in place. But I can go try to buy one locally and try it.
Maybe drill for a 5/16" spirol pin or groove pin?
amuller is offline
post #5 of 5 Old 04-12-2019, 10:16 AM
Thanks (Received): 375
Likes (Received): 1341
If you are going to retire it. I will take it off your Hands to use as a parts machine 4 "SR". : yahoo:
Similar Threads
726 final drive sprocket groove pin? amuller Toro Snowblowers 0 03-11-2019 02:56 PM
what do these numbers mean??? stromr Honda Snowblowers 5 02-21-2019 09:40 PM
Drive Sprocket for JD TRS32 DaHen Snowblower Repairs and Maintenance Forum 10 01-17-2018 03:34 PM
HS828 - Drive sprocket removal help - stuck 'keeper' pin gb387 Honda Snowblowers 1 11-02-2014 06:51 PM
Craftsman c950-52518-6. Drive chain jumping off axle sprocket. Why and how to fix? catalyst519 Snowblower Repairs and Maintenance Forum 2 02-18-2014 10:45 PM
