oil problem - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 03-24-2019, 09:04 AM Thread Starter
oil problem
My boss has a Toro, not sure of exact model. It's either a 7 or 8 HP Tec Snow King. It's an older model. The issue I have is that there seems to be oil leaking/spraying out of the breather. I know there are drain holes in the breather box, but could it also be something besides the plugged drain holes? If it may be a ring or valve issue, I would think it would smoke while running. It doesn't smoke at all. Just curious if I'm looking past something obvious. Thanks
Randy
rkchainsaw is offline
post #2 of 4 Old 03-24-2019, 09:13 AM
Thanks (Received): 112
Likes (Received): 298
Is the oil level correct or overfilled. Is there any gas in the oil which would have raised the oil level? That would indicate a problem with the float and needle in the carb allowing gas to flow through the jets, and into the intake, past the valve and into the crankcase.
Just some stuff to eliminate...
Work fascinates me.
skutflut is offline
Likes Blackstar, dbert liked this post
post #3 of 4 Old 03-26-2019, 09:12 PM Thread Starter
Yes the oil level is the first thing I checked. It is between the lines and there is no sign of gas leaking in the engine. I appreciate the response.
post #4 of 4 Old 03-27-2019, 12:44 AM
Thanks (Given): 202
Thanks (Received): 126
Likes (Given): 413
Likes (Received): 266
The breather assembly might be bad. Some have a check valve disc in them that could be cracked, or the packing material that catches the excess oil could be disintegrated and gone, it is like a course fibrous material like a course scotchbrite pad or almost like a steel wool material, and if that is gone, you will have oil spraying out the breather tube. A lot of times people just replace the breather assembly, lots of times it is part of the valve spring cover on the older flathead engines., or if an overhead valve engine, part of the valve cover assembly. They do go bad.
ST1100A is offline
Similar Threads
Carb problem solved, Who needs an ultrasonic cleaner! JLawrence08648 Snowblower Repairs and Maintenance Forum 18 03-08-2018 12:14 AM
Ariens 921005 Snow Blower Shaft Wobble Problem FrostyTheBeerMan Snowblower Repairs and Maintenance Forum 11 12-28-2017 09:28 AM
HS50 Governor Adjustment Problem Remedy orangputeh Honda Snowblowers 0 08-10-2017 04:41 PM
Problem solved? Report back to us. JLawrence08648 Snowblower Repairs and Maintenance Forum 9 03-20-2017 04:03 PM
2014 Platinum 24 Chute Problem. skybar Snowblower Repairs and Maintenance Forum 6 12-20-2013 06:08 PM
