Need to get 1980 Toro 826 running - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 05-29-2019, 05:37 PM Thread Starter
Shortlid's Avatar
Neighbor gave me a 1980 Toro 826. Model 38150, seriel 00008970. Said it ran two years ago but left outside. Paint actually in good shape except inside thrower. Engine free, and fires on Ether. However metal gas tank very corroded inside. Looking to get this runnong for a Veteran. Should I install modern plastic tank, what will fit?
ID:	155901   Click image for larger version
ID:	155903   Click image for larger version
ID:	155905   Click image for larger version
Shortlid is offline
post #2 of 6 Old 05-29-2019, 09:14 PM
Thanks (Received): 379
Likes (Received): 1377
The Plastic Tanks are 70-80 New and Far Better than the Metal 1's.
post #3 of 6 Old 05-30-2019, 11:09 AM
Thanks (Received): 212
Likes (Received): 767
Sounds like spark and compression are good, replace fuel lines, seal or replace tank, clean or replace carb, check belts, top off auger gearbox, adjust shoes, open up tranny and inspect rubber drive disc and replace if necessary, lube and adjust tranny, and clean and lube the steering clutches ( I believe that model has them )....great machine....I just hate the electric safeties....
cranman is offline
post #4 of 6 Old 12-01-2019, 11:24 PM Thread Starter
Shortlid's Avatar
Thumbs up
can you point me in the direction of a plastic tank that will fit?
Shortlid is offline
post #5 of 6 Old 12-01-2019, 11:58 PM
Thanks (Received): 23
Likes (Given): 41
Likes (Received): 47
look for a blown giant vac leaf blower engine and transfer the tank and lower support bracket. they used to sell it as an upgrade kit but now i can only find the bare tank
arienskids is online now
post #6 of 6 Old 12-02-2019, 01:47 PM
Go to Briggs&Stratton.com for the Tank. you will need new Brackets also.
