Toro 721R Motor Swap - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 09-28-2019, 01:30 PM Thread Starter
Thanks (Given): 276
Thanks (Received): 330
Likes (Given): 3361
Likes (Received): 683
I picked up a 2015 Toro 721R Power Clear for $50 locally with a busted connecting rod. The OP never added enough oil when purchased and after two years of light use, the rod finally seized and broke.
I think it had a Loncin motor and it LOOKED identical to the HF Predators. I had a Hemi version on the shelf and after removing the gas tank and muffler and installing the Loncin muffler on it, it fit perfectly on the 721 Power Clear. Access to the throttle and gas shutoff is still available, but tight.
Drilling a 1/8" hole in the choke lever allowed me to use the external choke control on the Toro. I also took the quick chute and zip deflector off my old 421 Power Clear and made the 721 a QZR model. Also added a 6' rope to the pull start, old was 5'. The machine has new looking paddles and scraper, so no extra cost there.
My daughter is getting the old 421 Power Clear with the electric start, manual chute control and flat head Tecumseh, which runs great.
Post Thanks / Like - 0 Thanks, 4 Likes, 0 Dislikes
Likes gibbs296, dbert, Zavie, nwcove liked this post
post #2 of 7 Old 09-28-2019, 03:16 PM
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 277
Likes (Received): 173
pics ???
Paul
paulm12 is online now
post #3 of 7 Old 09-28-2019, 05:55 PM
Likes (Received): 1383
Well it is aboot BLOODY FREAKING Time you went and got your paws Dirty around here. BROTHER GRUNT.
Likes Grunt, Zavie liked this post
post #4 of 7 Old 09-28-2019, 07:12 PM Thread Starter
Thanks (Given): 276
Likes (Given): 3361
Your right Todd, finally did something for ME and not the neighbors and friends. Funny thing, this month I put struts and shocks on my SUV and front rotors and brakes on the wife's car. My hands WERE so clean, people thought I was a mortician.
Likes paulm12 liked this post
post #5 of 7 Old 09-28-2019, 07:21 PM Thread Starter
Thanks (Given): 276
Likes (Given): 3361
Originally Posted by paulm12 View Post
pics ???
The Hemi is happy in it's new home. Plenty of clearance all around. Had to rotate the pull start 110 degrees to line up the rope with the shroud hole and connected the Toro key switch to the Hemi coil wire.
ID:	157337   Click image for larger version
ID:	157339   Click image for larger version
ID:	157341   Click image for larger version
ID:	157343   Click image for larger version
Likes Zavie, paulm12, gibbs296 liked this post
post #6 of 7 Old 10-04-2019, 02:32 PM
Not all 212ís are hemiís they are by vendor number, hopefully you did get one.
Thatís why HF has so many part numbers for same item. It means who made them for HF.
1993 8/24 Power Shift
2003 10/28 Power Shift
2003 CCR3650
2000 CCR Powerlite E
"50yrs" a Toro man
Cinci5 is offline
post #7 of 7 Old 10-04-2019, 03:06 PM Thread Starter
Thanks (Given): 276
Likes (Given): 3361
The Hemi's are the only ones with the aluminum rectangular valve cover, this is a Hemi.
