CCR2000- should I put money into it? - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 10-23-2019, 10:59 PM Thread Starter
I found a free 1992 CCR2000 on the curb and brought it home. I cleaned the carb and it starts and runs well now. Seems a little smoky to me however. Also put on new fuel line and filter I had lying around. Engaging the rotor seemed to slow it down slightly like maybe it’s low on power.
After I got it home it was obvious it needs a scraper and lower housing because of rust. Also needs a drive belt and probably paddles while I’m at it.
My question is should I put $100 in parts into it? Without snow can I tell if it will have adequate power? Seems like they’re being offered for around $150 here in Minneapolis.
1989 Toro 521
1995 Toro 724
2009 Toro Power Clear 221QR
Brent is offline
post #2 of 11 Old 10-23-2019, 11:59 PM
orangputeh's Avatar
Thanks (Given): 762
Thanks (Received): 235
Likes (Given): 1582
Likes (Received): 1671
Originally Posted by Brent View Post
I found a free 1992 CCR2000 on the curb and brought it home. I cleaned the carb and it starts and runs well now. Seems a little smoky to me however. Also put on new fuel line and filter I had lying around. Engaging the rotor seemed to slow it down slightly like maybe itís low on power.
After I got it home it was obvious it needs a scraper and lower housing because of rust. Also needs a drive belt and probably paddles while Iím at it.
My question is should I put $100 in parts into it? Without snow can I tell if it will have adequate power? Seems like theyíre being offered for around $150 here in Minneapolis.
For me it may be worth it if it were a keeper. If you wanted to sell then you'll probably lose money dollar wise and time wise.
so do you need it? or maybe you want to give it to someone as a gift? or resell and just make your money back.
or consider keeping it for a parts machine for a better CCR2000.
Those are my thoughts when i get a free machine.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #3 of 11 Old 10-24-2019, 06:11 AM
Thanks (Given): 173
Likes (Given): 460
Likes (Received): 1037
Like Puteh said... Only if you're going to keep it. Otherwise, pass. They're good little blowers but I wouldn't dump too much cash into it.
post #4 of 11 Old 10-24-2019, 10:39 AM Thread Starter
Thanks for the responses. Those are factors I was considering too. I think it would be worth $100 to me plus getting the satisfaction of bringing back into service. It should also be a good machine for my twelve year old to clear our ice rink off with being it’s light and clears down to the surface. I’ve never had a single stage before so they’re new to me.
I just don’t want to spend the money and find out there’s a problem with the engine’s power.
1989 Toro 521
1995 Toro 724
Brent is offline
post #5 of 11 Old 10-24-2019, 11:15 AM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
Toro and Honda make the best paddle snowblowers.
It's worth $100 to keep it and use it. It has a lot of power. You may want to postpone new paddles and see how it works unless you can tell it needs them.
post #6 of 11 Old 10-24-2019, 11:20 AM
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 277
Likes (Received): 172
Great machines with great engines, but the engine parts are expensive. With the single stage units, rust on the bottom is very difficult to fix, there just isn't alot of structure to work with. Are the paddle bearings and main pulley still moving freely? There is always some drop in speed when engaging the paddles on these, there just isn't alot of torque on the engines. They need to rev to work well, I think the engine speed is 3700 +/- 150 rpm.
and I have a few non-engine parts if you need still from one that I recently parted out (too much rust underneath)
Paul
paulm12 is online now
post #7 of 11 Old 10-24-2019, 11:44 AM
Thanks (Given): 20
Thanks (Received): 35
Likes (Given): 59
Likes (Received): 219
Thanks for the responses. Those are factors I was considering too. I think it would be worth $100 to me plus getting the satisfaction of bringing back into service. It should also be a good machine for my twelve year old to clear our ice rink off with being itís light and clears down to the surface. Iíve never had a single stage before so theyíre new to me.
I just donít want to spend the money and find out thereís a problem with the engineís power.
i have had many of these. i wouldn't think something is wrong power wise. if your feeling frisky check the compression if its good not much else in a 2 stroke can go wrong.
make sure the governor is working freely if you start it up with the bottom carb cover off you can see what is happening and even rev it up by hand and see how it sounds.
once it gets a load on it with they really open up the flap on the carb and let in all the air and bark pretty good in 8+ inches of snow.
i love the 2000 they are really good power to weight ratio. easy to lift by yourself into a truck bed ect.
Toro 621 6hp 4 cycle ....Craftsman SS ???
....Honda HS624 GX160 Toro 828 lxe Tecumseh 8hp
Snowbelt_subie is offline
post #8 of 11 Old 10-24-2019, 01:15 PM Thread Starter
Everything’s spinning freely. I think it’s just the lower housing that’s rusted out. I think I’m going get that piece, an aftermarket scraper and aftermarket belt from eBay. I’ll replace paddles later if necessary as suggested.
1989 Toro 521
1995 Toro 724
Brent is offline
post #9 of 11 Old 10-24-2019, 01:20 PM Thread Starter
I will check the governor operation. Thanks. I did check the compression but I don’t trust my cheap gauge. It read about 60 psi and from what I understand it shouldn’t even run with it that low. I need to figure out a way to cross check that with a good gauge.
1989 Toro 521
1995 Toro 724
Brent is offline
post #10 of 11 Old 10-30-2019, 12:09 AM
Thanks (Given): 9
Thanks (Received): 19
Likes (Received): 26
Those engines sometimes like to loose spark when warm. let it run for awhile to see if it cuts out before you put too much money in it. Good blowers when running good. Also some of the parts are NLA like the belt cover, and if that has a hole worn thru the belt can get wet and slip under load.
Snowblowers in the shed. All made in the good ol USA.
Bobcat 28" 2 stage 8hp Briggs
Bobcat 24" 2 stage 7hp Briggs
Bobcat 20" 2 stage repowered with Tecumseh OHH50
Lawnboy Snowboy
Lawnboy Snowboy self propelled
Toro 6000 Rtek Powered
Toro CCR2000 Suzuki Powered
Toro CCR2500 Tecumseh Powered
Toro CCR3650 boxy one, Rtek Powered
sj701 is offline
