Toro plastic key. Leave in or not? - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 10-28-2019, 09:14 AM Thread Starter
Likes (Received): 24
Just got a new Toro QZE 821 and it has a plastic key.
I'm not real familiar with these types of keys.
I found out that you press in all the way In for it to start and pull out to turn the engine off.
On my toro 721 you had an actual key that you'd turn to the on or off position.
Question.
There are a couple positions for this plastic key. All the way in, you can start the engine, then there's a middle position were the key just seems to sit there and then fully out.
Do I need to leave the key in a certain position when I'm not using the snow blower? I just realized I had it fully pushed in. Will it harm anything leaving it fully pushed in?
It was easy for me to simply turn it to the off position on the 721 since it was a real key and you had an off position.
Thanks.
Sold Honda HS620 to buy Toro QZR621
Sold Toro QZR 621 to buy Toro QZE 721
Sold Toro QZE 721 to buy Current Toro QZE 821
steeve725 is offline
post #2 of 10 Old 10-28-2019, 09:57 AM
Thanks (Given): 175
Likes (Given): 465
Likes (Received): 1045
Stick it in all the way and leave it.
post #3 of 10 Old 10-28-2019, 10:03 AM Thread Starter
Thanks. I appreciate it.
post #4 of 10 Old 10-28-2019, 10:36 AM
Thanks (Given): 276
Thanks (Received): 330
Likes (Given): 3361
Likes (Received): 683
If you ever lose the keys, a coffee stirrer, popsicle stick or a stiff piece of cardboard will work.
post #5 of 10 Old 10-28-2019, 10:42 AM Thread Starter
Good to know
post #6 of 10 Old 10-28-2019, 11:35 AM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 147
Likes (Received): 297
All that key does is break the grounding of the coil, When you pull it out it connects the wire and grounds out the coil so it has no spark, Push it in and it breaks the connection and allows the plug to spark., Most just leave it in the machine so not to misplace it.
Dauntae is offline
post #7 of 10 Old 10-28-2019, 08:50 PM
Thanks (Given): 97
Likes (Given): 76
Likes (Received): 463
I usually disconnect it and turn it off with the throttle.
JLawrence08648 is offline
post #8 of 10 Old 11-15-2019, 07:20 PM
Some like to push it all the way, others like some in- some out. Others like to pull it out. Do whichever makes you (and her) feel better
The machine is the her - get your minds out of the gutter !!
rccrfan1 is offline
post #9 of 10 Old 11-16-2019, 06:44 AM
Thanks (Given): 19
Thanks (Received): 99
Likes (Given): 747
Likes (Received): 268
leave it in,move the throttle to full off to stop
87powershiftx2 is offline
post #10 of 10 Old 11-16-2019, 10:38 AM
Thanks (Given): 276
Likes (Given): 3361
The 721's and 821's being discussed are single stage machines with no throttle control.
