Toro 826 fuel tank issue - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 11-03-2019, 08:09 PM Thread Starter
Hi guys, new to the forum here. I have a Toro 826 the model appears to be 38150(its a little worn) and it hasn't ran in two years. I tried putting gas in the tank to try and start it and discovered a fuel leak right at the tank immediately. Where the shutoff screws into the tank it is cracked. I tried searching for parts without luck, can anyone direct me to a good source for parts or a universal replacement?
Thanks,
Ron
Ronn is offline
post #2 of 13 Old 11-03-2019, 09:26 PM
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 277
Likes (Received): 173
you'll need to enter the serial number here, then you can see the parts diagrams.
https://www.toro.com/en/parts?Search...tion=equipment
Paul
paulm12 is online now
post #3 of 13 Old 11-04-2019, 08:41 AM Thread Starter
Thanks, the serial number is 7000480. Doesn't look like the gas tank is listed.. must be a discontinued part then?
If so, has anyone had success with another style of tank from another machine?
I'm also curious about the year, how do you tell from the model and serial number?
Here is a picture of the blower with my helper.
Ronn is offline
post #4 of 13 Old 11-04-2019, 09:54 AM
Thanks (Given): 172
Likes (Given): 1217
Likes (Received): 303
Plastic tank? I think they are around $100 on Amazon, ebay, etc. Repair kit is about $10. Worth a shot...Nice helper!!
gibbs296 is offline
post #5 of 13 Old 11-04-2019, 10:42 AM
Thanks (Given): 63
Likes (Given): 277
try here: https://www.jackssmallengines.com/ja...190406-3054-01
tank: https://www.jackssmallengines.com/ja...tratton/691993
Jacks Small Engine is an excellent resource for info, and reasonable on prices too.
Paul
Thanks Ronn thanked for this post
post #6 of 13 Old 11-04-2019, 01:38 PM Thread Starter
Thanks guys, I have the plastic tank on order and it should be here next week. I will post an update when I get it.
Ronn is offline
post #7 of 13 Old 11-04-2019, 02:34 PM
Likes (Received): 1383
That is a BRIGGS Part Number not TORO.
post #8 of 13 Old 11-04-2019, 02:35 PM
The year is 1984.
post #9 of 13 Old 11-20-2019, 02:06 PM Thread Starter
Hey guys, just wanted to provide an update. I ordered the fuel tank from the part number listed on jacks small engines. It is a Briggs part as said above. The fit was great and the blower is up and running.
The only issue I'm having now is once I shut it off, fuel begins leaking out of the carb from the inside. It isn't fast so I'm thinking that varnish on the needle surface isn't the culprit. It appears to be dripping from the bottom bolt that holds on the air intake. It is a 3 bolt flo jet updraft carb. If I turn the gas off and run it out of gas there is no issue. I did some reading and some info I got was that the seating surface on the emulsion tube needs an o-ring.
I will look into this and post back. Feedback is welcome.
Ronn is offline
Likes Grunt liked this post
post #10 of 13 Old 11-20-2019, 03:19 PM
Thanks (Given): 202
Thanks (Received): 126
Likes (Given): 420
Likes (Received): 266
That is an old model and the carburetor is a very old design that had problems with the fuel leaking unless you turned off the fuel valve when it is not running, so that is normal for the leakage.
If those older designed carbs did not leak, then you knew you had a problem with them, it is very common for them to drip.
Other than that, the old Briggs engines were built better than a lot of the new ones.
ST1100A is offline
Thanks Snowcat thanked for this post
