Power Max 826 OE snowthrower question - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 11-18-2019, 11:33 PM Thread Starter
Question Power Max 826 OE snowthrower question
I purchased the Toro Power Max 826 OE snowblower as a new machine 3.5 years ago. Today while changing the oil, I observed something I had never noticed before.
See the "what is this?" question I posted in the photo.
It has a screw-off cover, that when removed reveals some type of reservoir that is either empty or has a fluid farther down. The Toro manual says nothing about this. Just curious, if anyone knows what this is????
Kal Perry is offline
post #2 of 6 Old 11-19-2019, 12:29 AM
Thanks (Received): 32
Likes (Given): 46
Likes (Received): 52
That is an access to the engine oil sump. There is usually another one on the other side of the engine. When the oil is just about to run out of that port, the engine oil is at the full level.
1997 Toro 724
1997 Toro 824XL Power Throw
toromike is online now
Thanks Kal Perry thanked for this post
post #3 of 6 Old 11-19-2019, 08:45 AM
Thanks (Given): 19
Thanks (Received): 99
Likes (Given): 747
Likes (Received): 268
normal,leave it alone, snowblower motors are winter modified lawn mower /equipment engines they use 2 sometimes 3 oil fill areas like you show, if it has a dip stick use it only, forget about the fill level screws which could have a plug like you point out or one spot that is not machined on the other side at the same level .
87powershiftx2 is offline
post #4 of 6 Old 11-19-2019, 03:01 PM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 60
Likes (Given): 131
Likes (Received): 221
On more generic engines, those plugs (typically one on each side of the crankcase) are the way to check & change the oil. Toro, being more thoughtful, gives you the traditional dipsick for ease of use.
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #5 of 6 Old 11-19-2019, 06:37 PM
Location: Split between Manchester and Deep Creek Lake Md.
Thanks (Received): 8
Likes (Received): 20
When I picked up my new blower with the 305cc briggs engine (which has two plastic screw in caps + the oil fill dip stick tube) I was told by the shop guy to make sure they are tight several times during the season as he has seen them come loose or come out and by the time the operator noticed it was too late and the engine was toast.
toms is offline
post #6 of 6 Old 11-20-2019, 05:31 AM
Likes (Received): 24
My brand new Toro 821QZE with the 252cc engine has the oil fill plug were you fill and check the oil, it’s the plug that you say comes on more generic engines. The manual for 821 QZE online shows the 821 QZE has the fill tube like all the other 252cc engines that Toro has in the other The above transmitter.
In my case I guess Toro wasn’t more thoughtful
Sold Honda HS620 to buy Toro QZR621
Sold Toro QZR 621 to buy Toro QZE 721
Sold Toro QZE 721 to buy Current Toro QZE 821
steeve725 is offline
