What is top governed speed on HMSK80, and HMSK90 difference - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 12-11-2019, 12:23 PM Thread Starter
Hi All,
Does anyone know the top governed speed to set the HMSK80?
I've seen 3250rpm, but not sure.
Also, I've been researching the differences between HMSK80, 90, & 10.
Seems like the HMSK80 is the same as the HMSK90 in terms of bore and stroke, so I'm thinking bigger jets, or HP quoted at a high RPM....things the auto manufacturers used to do in the early 70's to keep insurance premiums down
I know the HMSK100 just has a bigger bore....everything else the same as the HMSK80.
What do you guys think?
dinky
dinkyguitar is offline
post #2 of 7 Old 12-11-2019, 12:43 PM
Thanks (Received): 99
Likes (Given): 68
Likes (Received): 223
Originally Posted by dinkyguitar View Post
Hi All,
dinky
all 318cc are a real 7.8 hp engine not matter if it called and 8hp 8.5 hp or 9 hp
12.75 lb ft torq
11.5x3600 equal 41400 div by 5252 equals 7.88 hp on its best day
358cc rated 10 hp 10.5 and 11 hp are all the same
15.5 lb ft torq
14x3600 equals 50400 equals 9.59 hp on its best day
top gov speed is 3600 plus or minus 150
they dont thow well at 3200
the buyers who paid extra for a 318cc 9hp or 358cc 11 hp got hosed
1132le is offline
post #3 of 7 Old 12-11-2019, 12:57 PM
Thanks (Received): 28
Likes (Given): 143
Likes (Received): 57
12.75 lb ft torq
15.5 lb ft torq
Then, you have this guy next door.....Show off!!!
One V8 engine later and this snow blower is a beast!
2019 Ariens Compact 24...
penna stogey is online now
post #4 of 7 Old 12-11-2019, 01:54 PM
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 277
Likes (Received): 173
My current blowers with Tecumseh L-head motors (HS40, HSK50 and HSK70) have no-load rpms spec'd at 3200 and 3300 rpm. So the hp at those rpms would be even lower than the rated max. I know you can (usually) rev them higher, as 1132le says.
thanks
Paul
paulm12 is online now
post #5 of 7 Old 12-11-2019, 01:57 PM Thread Starter
ok thanks,
I'll set top governed speed for 3600rpm +-150
dinky
post #6 of 7 Old 12-11-2019, 05:13 PM
Thanks (Received): 212
Likes (Received): 767
I'd aim for less over more with a Tec....
cranman is offline
Likes Jackmels, classiccat, 87powershiftx2 liked this post
post #7 of 7 Old 12-11-2019, 06:58 PM
Thanks (Given): 97
Likes (Given): 76
Likes (Received): 463
I go to 3,450
JLawrence08648 is offline
