1979 toro 524- (38040) rebuild. - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 12-15-2019, 11:42 PM Thread Starter
Likes (Received): 9
Well its been a while since joining the forum and posting my thoughts of doing a repower project. Sorry for not posting as the build took place. i just get caught up in the project. Anyway my toro has what i think is one of the best Techumseh engines HS50-67074B so taking that off and slapping some new junk motor was absolutely not an option. so i took the long long very expensive route of doing a complete breakdown and rebuild with no aftermarket engine parts. here are just a few pictures of it done but i promise ill put a nice group of pictures together to show the build when i get a few min to go through them all. 1979 toro 524- (38040)  rebuild.-15764709248103666243570896097283_1576470957539.jpg
hoaned out cylinder
new standard rings
breather assembly
valves& springs
head gasket
actually every engine gasket is new
new muffler
gas tank
fuel lines
carburetor rebuild
electric starter
other than the engine
auger gear box rebuild with all new internal parts
impeller bearing with hardware.
upgraded about 80 percent of the hardware to stainless steel
new oversized tires for tough new england weather
belts
friction disc
lots of new bolts, nuts, bearings to make the transmission work for all 3 gears forward and 2 reverse.
new wiring for on/off switch
a few sticker decals
idler pulley
brake pad
shoes
the pictures i put up are from beginning Click image for larger version
ID:	161047   Click image for larger version
ID:	161049   Click image for larger version
ID:	161051   Click image for larger version
ID:	161053   Click image for larger version
ID:	161057   Click image for larger version
Swortman35! is offline
Post Thanks / Like - 1 Thanks, 4 Likes, 0 Dislikes
Thanks eyebolt thanked for this post
Likes classiccat, Grunt, toromike, eyebolt liked this post
post #2 of 12 Old 12-15-2019, 11:50 PM Thread Starter
Likes (Received): 9
i also did a repower with my wifes snowblower. yes, we each have our own his and her toros 521& 524 i put a 7hp ohv Techumseh on hers. i couldn't afford another vintage rebuild right now.
ID:	161061   Click image for larger version
ID:	161063   Click image for larger version
ID:	161065   Click image for larger version
ID:	161067   Click image for larger version
Likes classiccat, Grunt, toromike liked this post
post #3 of 12 Old 12-15-2019, 11:56 PM
Thanks (Received): 11
Likes (Given): 34
Likes (Received): 24
Hi swortman
Looks really nice. I did the predator swap on an Ariens 10000 series and I'm glad I did. I thought about a costly rebuild, but price changed my mind. I loved that Tecumseh engine, but 50 years was long enough for me.
Again, you did a great job!
Ariens 1969 10,000 Series-- Tractor 10965 serial # 005841 with 10995 serial # 023507 Sno-Thro
Ariensboy is offline
post #4 of 12 Old 12-16-2019, 03:51 AM
Thanks (Received): 28
Likes (Given): 143
Likes (Received): 57
Congrats Swortman, well done sir...Very nice!
2019 Ariens Compact 24...
penna stogey is online now
post #5 of 12 Old 12-16-2019, 05:39 AM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
Where do you get the "Toro" Replacement Stickers?? Great looking rebuild, I have that same machine....needs an O/H, plus 724. 826 and 624 PowerShift.
GLuck, Jay
JayzAuto1 is offline
post #6 of 12 Old 12-16-2019, 06:25 AM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2045
Likes (Received): 517
Hats off to you keeping old iron alive and well!
Who's machine had the "Keep your ********* off of my Toro"?
Those old school tecs are definitely a different beast than the modern era engines; once you get them dialed-in, the really purr (and growl when needed)!
('87 Toro 38150 826)
post #7 of 12 Old 12-16-2019, 09:04 AM
Thanks (Given): 79
Thanks (Received): 83
Likes (Given): 330
Likes (Received): 362
Looks good in black.
Kudos for sticking it out with the Tec
1989 John Deere 1032
tdipaul is offline
post #8 of 12 Old 12-16-2019, 10:21 AM
Thanks (Given): 276
Thanks (Received): 330
Likes (Given): 3361
Likes (Received): 683
Very nice work. They will both be running for another 30 years.
Nice valve stem caps on the tires, you must be from the Northeast.
post #9 of 12 Old 12-16-2019, 01:33 PM
Thanks (Received): 212
Likes (Received): 767
I just picked up a 5 24 in great shape that just needed an impeller bearing. A 30 minute $15 fix. I got it from the original owner who just bought a new Ariens and didn't want to go through the repair. Well worth the $20 I gave for it......mine has a red engine....was the black engine standard in 79?
cranman is offline
post #10 of 12 Old 12-16-2019, 10:31 PM
Thanks (Received): 26
Likes (Given): 120
Likes (Received): 98
Very nice work there,Swortman.I'm glad you saved the original engine,once they're gone-they're gone.
I also Have a Toro 521 that I repowered with a Harbor Freight Greyhound 6.5hp about nine years ago.As much as I like the reduced noise and fuel economy of the OHV design,I am convinced that the original Tecumseh HS50 had a good deal more torque.
Unfortunately,something managed to find its way into the cylinder of the TEC, made two huge grooves and ruined the engine.
I wouldn't mind putting a low-hour Tec. 5 or 6hp engine back on it,but I'd really like to find a good old flathead Briggs for it.Don't see many of the old Briggs in winter clothes around here any more.Last one I had was a 7hp,somebody offered me ridiculous money for it and it was gone.
Mike C. is offline
