electric start no work - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 12-18-2019, 09:44 PM Thread Starter
I recently acquired a Toro model ccr 2500e. The electric start does not work. Is there any info on how to repair this function? Thank you!
hammer6315 is offline
post #2 of 6 Old 12-19-2019, 07:11 AM
Thanks (Given): 175
Likes (Given): 465
Likes (Received): 1045
Maybe this?
post #3 of 6 Old 12-19-2019, 08:01 AM
Likes (Received): 1383
I Think you can get new ones on E-bay also.
post #4 of 6 Old 12-19-2019, 08:35 AM
Thanks (Received): 151
Likes (Received): 546
@hammer,
Usually, the small spiral gear under spring tension on the end of the starter that spins the flywheel is the culprit. Those parts can be purchased from Amazon, etc.
Most have a C clip that needs to be spread apart in order to change out the defective gear. They make a tool to do remove it, but you can improvise, although it is a little tricky, it can be done.
One reason a lot of the gears are destroyed, is that the starters vibrate loose from the engine in many instances, thus misaligning the gear to the flywheel. Always periodically check the starter bolt's where mounted for tightness.
Update … I see he was referring to a single stage … disregard my post referring to a 2 stage starter, as I do not own a single stage.
oneacer is online now
post #5 of 6 Old 12-19-2019, 08:47 AM
Thanks (Given): 7
Likes (Given): 29
Likes (Received): 22
Toro also implemented using a Large Zip Tie to secure the electric starters in the single stage throwers to keep vibration from loosening them.
KennyW in CT is offline
post #6 of 6 Old 12-19-2019, 09:46 AM Thread Starter
Thanks for the reply. It is a single stage 2500E. When I push the button, I get nothing. I checked and it seems the push button is OK. So, suppose something is wrong further down at the starter itself.
