Toro 824OE hard to manuever - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 12-19-2019, 07:30 PM Thread Starter
I have a new 824 OE and am not pleased with how hard it turns compared to my previous toro 2 stage. A friend suggested that I pull one of the pins on a wheel to make it easier to handle. Won’t that approach cause it to lose pulling power from that wheel. I couldn’t find anything in the manual about the wheel pins. I assumed both pins had to be installed to give positraction.
post #2 of 14 Old 12-19-2019, 09:04 PM
minnesotaman82's Avatar
You are correct. Pulling the pin will basically open the “differential”. It will allow the wheels to turn at different speeds and make it much easier to turn but it will basically cut your traction in half. That’s why a lot of the bigger (and more expensive) blowers have trigger or automatic steering, so that you can the best of both worlds.
John Deere TRS 24
John Deere 928E
John Deere 1330se
Briggs and Stratton 1227MD
Toro 826 OAE
minnesotaman82 is offline
post #3 of 14 Old 12-20-2019, 06:18 AM
Thanks (Received): 173
Likes (Given): 414
Likes (Received): 661
if you unpin one wheel the machine will want to always steer in that direction, it could be more of a work out than what you are dealing with now.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #4 of 14 Old 12-20-2019, 08:36 AM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 60
Likes (Given): 131
Likes (Received): 221
Perhaps you are getting older and loosing muscle mass . . .
Just show that new Toro who’s boss.
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
Likes Shovel liked this post
post #5 of 14 Old 12-20-2019, 08:56 AM
oneacer's Avatar
Thanks (Received): 147
Likes (Received): 538
@tpen,
…. I agree, I never have had a turning issue with any of my machines, I just turn the machine. I do find turning in the road on the first pass to be the easiest though ….
oneacer is online now
post #6 of 14 Old 12-20-2019, 05:14 PM Thread Starter
I am spoiled by my old 828lxe that had the triggers. When I bought this 824oe I thought it had that automatic steering. I only used it a half hour and got buyers remorse disease. Do you think my hardware store will take it back and order one with automatic steering?
post #7 of 14 Old 12-20-2019, 06:14 PM
Thanks (Given): 168
Thanks (Received): 334
Likes (Given): 464
Likes (Received): 823
Gas equipment can be iffy to return, but there's only way to find out if they'll take it back. Sorry to hear the new machine isn't doing what you'd hoped.
My 2-stage has a differential, which makes it really easy to turn (it will pivot in-place), but if 1 wheels slips, I stop moving. I can manually lock the differential together for more grip, but then of course it's harder to turn (especially with chains). Trigger-controlled steering sounds like the best option, to me, though I haven't gotten to use it yet. You get the traction of the wheels locked-together when going straight, then squeeze a trigger to turn freely. Should be simple and effective.
Good luck!
post #8 of 14 Old 12-23-2019, 05:18 PM
I doubt they would take it back especially after being used, but you never know. I feel you when it comes to buyers remorse. I had the same happen to me. Bought a B&S snowblower for just over $1,000. Used it a couple of times and didn't like it. Took it back to the dealer and the would only give me $750 for it!
Needless to say, I never went back to that dealer.
post #9 of 14 Old 12-23-2019, 07:33 PM
Thanks (Given): 33
Thanks (Received): 65
Likes (Given): 114
Likes (Received): 133
I have a solid axle machine...Turning is much easier with power applied to the wheels.
If I need to turn around using a left for instance ..I pull up on the left handle bar and push right on the right handlebar.. the inside tire goes light and she spins right around..Just kind of give it a jerk over to lighten that inside tire...Works great in the higher speed ranges..the faster you are going the lighter that inside tire is.
Its a bear on dry concrete.
If you are in a tight area and it's hard to maneuver I find it best to just lift up some on the handles to lighten the weight on the tires then scoot it in the desired direction.
Shovel is online now
Thanks barney thanked for this post
post #10 of 14 Old 12-24-2019, 04:03 AM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 183
push down on the one handle the side u want to turn into while in gear
MY VIDS ON FIXIN HER UP
vinnycom is offline
