Weird S-200 carb - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 12-21-2019, 02:18 PM Thread Starter
Weird S-200 carb
I bought a "broken" Toro S-200 for $20 to repair and sell for a profit when the first big snow hits. The guy said it wouldn't run and my experience with the S620 I bought told me it probably just needed attention to the carb. Sure enough the diaphragm was petrified, so I disassembled, soaked in a gunk pail for 24 hours, blew out and started rebuilding. I noticed the main adjustment screw was missing and the weird thing about this carb is that the hole where it goes isn't even threaded and there's what seems to be a welch plug way down in the bottom. I uploaded a pic. I've never seen this before... all of the exploded views I've seen of this show both screws. I don't see any other adjustments on the carb, it's otherwise exactly like the usual 200-620 Tecumseh carbs. Possible this style of carb was used on other applications and this carb came from something different, like a pump engine or similar? I'm not sure if this will be ok or if it's gonna cause problems.
wallaceroger is offline
post #2 of 4 Old 12-21-2019, 04:47 PM
Thanks (Given): 276
Thanks (Received): 330
Likes (Given): 3354
Likes (Received): 679
My ex brother-in-law has an S200 with the same single screw carb. I put a kit in it a few years ago and it still runs good, for what it is. The motor is a fixed throttle, so just adjust the screw for best running.
post #3 of 4 Old 12-21-2019, 10:51 PM Thread Starter
Good to know! I guess some came off the line like that, weird but if it works that's all that matters!
post #4 of 4 Old 12-21-2019, 10:54 PM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
Likely is was a way to comply with the EPA mandate of no adjustable carbs without needing to make new molds for carb bodies. Fit a fixed jet, drive a plug behind it and done . . .
tadawson is online now
