726 (37771) Auger Bearing Replacement - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 12-27-2019, 04:36 PM Thread Starter
Hello,
Took on a big project for myself, replacing the auger bearing in my Toro 726OE, model 37771. I'm to the point now where I have the auger disc off and I need to get the impeller hub off. Just wondering if anyone has any experience with this? From what I can tell, it must just be brute force to get it off? There is no set screw that I can see.
Here is the diagram --> https://lookup3.toro.com/Ill/2X/420/...?1577479758216
I'm trying to get part 4 off, to change part 5.
Any info would be appreciated!
Name:	Screen Shot 2019-12-27 at 6.05.36 PM.jpg
mccarma is offline
post #2 of 4 Old 12-28-2019, 03:05 PM Thread Starter
Got it off with a ball joint separator after. Fun stuff.
mccarma is offline
Likes Grunt liked this post
post #3 of 4 Old 12-28-2019, 04:43 PM
Thanks (Given): 589
Likes (Given): 4362
Likes (Received): 1741
It looks like the bolt retains it and it's supposed to be a slip fit onto the shaft as there is a flat on the shaft and the inside of the hub. Add rust and you're looking at using a little persuasion (hammer, gear puller, ...) , penetrating oil and maybe heat.
Have you tried something like a steering wheel puller ?? You can usually get one on loan from an auto parts store if you don't have one or want to buy one.
Name:	steering wheel puller.jpg
post #4 of 4 Old 12-29-2019, 11:10 AM
Likes (Received): 1379
I Just Bought This 1 from MAC TOOLS The other day. https://www.mactools.com/en-us/Speci...-Bolt-Grip-Set
