1132 old school + 824 Powershift compatible? - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 12-29-2019, 07:33 AM Thread Starter
Likes (Received): 17
Greetings, all!
I have an 824 Powershift that runs beatifully. I could get an 1132 cheaply. Toying with possibilities ...
a. The 11 hp engine would be a straight fit onto the 824, is that right?
b. Would the auger house from the 1132 fit onto the 824? My guess is no, because of the 12" vs 14" impeller. But if it did, I could have myself an 1132 Powershift!
Anyone?
__________________________________________________ _____________
Eastern Norway, -25 degree winters, +30 summers (some years ...)
1990 Toro 824 Powershift
Unknown year Partner 5-61/HM50, for sale
Norwegian is offline
Thanks eyebolt thanked for this post
Likes eyebolt liked this post
post #2 of 7 Old 12-29-2019, 07:46 AM
Thanks (Received): 99
Likes (Given): 737
Likes (Received): 262
the engine should be a bolt down, you may have to move the engine mount studs to another mount hole, you will possibly need to use the engine pulley and find belts to fit as the 11 hp engine shaft will sit higher than the 8hp, maybe there will be enough slack in the belts when the drive traction pulley assembly is loosened
either way a 11 on a powershift should make it a bear to use.
87powershiftx2 is offline
post #3 of 7 Old 12-29-2019, 08:26 AM
Likes (Received): 1379
Originally Posted by Norwegian View Post
Greetings, all!
Anyone?
ALL POWERSHIFT'S Ran a 12 inch Impeller on them. outside of maybe different belts between The BRIGGS and that Gutless wonder of a so called Engine. every thing else is interchangeable.
post #4 of 7 Old 12-29-2019, 09:25 AM Thread Starter
Thanks for those fast replies. Just to clear it up - the 1132 in question is NOT a Powershift. So the question is, will an old school 1132 auger house fit on a 824 Powershift frame?
post #5 of 7 Old 12-29-2019, 09:33 AM
Thanks (Received): 212
Likes (Received): 767
I don't think so, but Todd would be the guy to ask.
cranman is offline
post #6 of 7 Old 12-29-2019, 11:07 AM
NO!!!!!!!!!!!!!!!!!!!!
post #7 of 7 Old 12-29-2019, 04:20 PM
Likes (Received): 22
Not without a torch & a welder!
If I can't fix it, I can screw it up so bad that no one else can either!
Greg13 is offline
