Draining oil on 724 QXE - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 12-30-2019, 08:48 PM Thread Starter
I picked up a new 724 QXE this year, and have run it for a few hours now, and I'm trying to change the oil. I let it run for a few minutes, unscrewed the drain bolt on the back, tipped it back, but nothing is coming out. Thinking I must be going crazy, I double-checked that there was oil in the machine...and yep, there was.
Clearly I'm missing something. Any ideas?
bguidinger is offline
post #2 of 7 Old 12-30-2019, 09:18 PM
Can you show us a picture of the bolt you unscrewed? Just be sure?
John Deere TRS 24
John Deere 928E
John Deere 1330se
Briggs and Stratton 1227MD
Toro 826 OAE
minnesotaman82 is offline
post #3 of 7 Old 12-30-2019, 09:57 PM Thread Starter
Picture attached.
Edit: also, I stuck a screw driver in the hole, and it went in about 2 inches, and then stopped. Seems like there's something blocking it, or maybe the hole was never drilled out properly at the factory.
post #4 of 7 Old 12-30-2019, 10:34 PM
Thanks (Given): 79
Thanks (Received): 83
Likes (Given): 329
Likes (Received): 362
Something never seen before, that is. Jeesh.
Email the pic to the Seller and request a proper new tube piece.
1989 John Deere 1032
tdipaul is online now
post #5 of 7 Old 12-30-2019, 10:54 PM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
Pull the tube next..... Unscrew it using the wrench flats on the end of the tube....... Stand back, JIC, it may drain quickly at this time....
GLuck, Jay
JayzAuto1 is offline
post #6 of 7 Old 12-31-2019, 05:29 AM
Likes (Received): 22
If for some reason it still won't drain after removing the tube you can always pump it out. I have this B&S pump I use sometimes.
https://smile.amazon.com/gp/product/...ch_asin_title?
1996 MTD 5/22
2016 Toro 721 QZR
DuffyJr is offline
post #7 of 7 Old 12-31-2019, 11:10 AM Thread Starter
That did it! Took the tube off and it started draining as expected. I looked down the tube and it definitely wasn't drilled out properly. Not sure how that passed QC....
Thanks for the help!
