Toro PowerMax 724 - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 01-30-2020, 09:19 PM Thread Starter
Toro PowerMax 724
There is a slight intermitttent squealing sound when the auger is engaged. What could this be? Expecting more snow the weekend and dont want it to become a bigger problem.
Ritetool is offline
post #2 of 4 Old 01-30-2020, 10:52 PM
Most likely what you are hearing is belt squeal for a second when everything engages??
Johnny G1 is online now
post #3 of 4 Old 01-31-2020, 12:01 AM
Thanks (Given): 33
Thanks (Received): 66
Likes (Given): 116
Likes (Received): 138
Agreed.. Doesn't hurt to check that the belt tension is proper but a brief squeal from the belt is normal.
Mine is silent for the first several minutes but will give a chirp after that.
Shovel is online now
post #4 of 4 Old 02-07-2020, 06:03 AM
Thanks (Received): 99
Likes (Given): 742
Likes (Received): 264
you can try adjusting the belt tighter but you will still hear it a little as a snowblower belt tension-er is designed to allow a little slippage so if something big gets inhaled into the auger the belt slips stopping the auger
they are NOT 100% grab to the pulleys
87powershiftx2 is offline
