year of power shift 1028 - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 33 Old 02-03-2020, 07:36 PM
Likes (Received): 20
If the first picture is the one you are looking at, it has the serrated auger. It seems like they were in the later models. Others will know what years.
Power shifts are as close to bullet proof as you can get. Do the maintenance and they will run forever.
If I can't fix it, I can screw it up so bad that no one else can either!
Greg13 is offline
Likes squid3083, 87powershiftx2 liked this post
post #12 of 33 Old 02-03-2020, 08:15 PM Thread Starter
squid3083's Avatar
Likes (Received): 16
You are right, after looking closer it has serrated auger.
Was looking at that specific model bcus the snow is very packed in front of the house about 30 feet wide and on both sides of my car port, so I need something a bit heavy to plow through.
squid3083 is offline
post #13 of 33 Old 02-03-2020, 09:43 PM Thread Starter
squid3083's Avatar
Originally Posted by 87powershiftx2 View Post
nah! 5w30 oil i've fired by hand at minus 20 here .it should have a starter unless it failed and was never replaced, also should have a differential on the axle which makes for easier turns or locked for major traction
note the grease fittings on the legs are my own doing as the bushings like to seize to the axle and spin other wise making the legs bad . it's a easy do and helps retain the bushings
Nice mod if I get it will do the same mod.
Weird that the back of the snow blower is oppenned like that ??
post #14 of 33 Old 02-04-2020, 05:14 AM
Thanks (Given): 16
Thanks (Received): 61
Likes (Given): 483
Likes (Received): 154
to do the mod the legs have to come off, drilled though so the grease can go in,
open that way as the powershift needs all that room to move front and back, . serrated augers came about around?? 1990 my 88 didn't my 97 did have
87powershiftx2 is offline
post #15 of 33 Old 02-04-2020, 07:41 AM
Thanks (Received): 375
Likes (Received): 1341
Hi savy toros owners. I am looking at this snow blower, only have a pic so far.
The guy says max 10 years. I know it's older.
Can anyone tell me how old it is
Power shift 1028
I have seen pict of toro 2010 and they seem newer then this one.
1996- 2004 Model year.
post #16 of 33 Old 02-04-2020, 06:52 PM Thread Starter
squid3083's Avatar
So bought it this afternoon negotiated a starter bcus it did not have one. Will try to attach couple of pics I took.
ID:	163567   Click image for larger version
ID:	163569   Click image for larger version
ID:	163571   Click image for larger version
1999 Yard man 9 27 31AE653G501 with impeller mod
Post Thanks / Like - 0 Thanks, 5 Likes, 0 Dislikes
post #17 of 33 Old 02-05-2020, 01:17 AM Thread Starter
squid3083's Avatar
So.... with serial and model number
The PartsTree says my snow blower was made in 1995 ???
8555 (1028) - Toro Power Shift Snow Thrower (SN: 059000001 - 059999999) (1995)
post #18 of 33 Old 02-05-2020, 07:19 AM
Thanks (Given): 16
Likes (Given): 483
yes a 1995 model ,did the other owner install a diff kit? 95 was well before it was made standard and the model number changed
post #19 of 33 Old 02-05-2020, 07:51 AM
Thanks (Given): 228
Thanks (Received): 195
Likes (Given): 2021
Likes (Received): 513
Congrats! Welcome to the Toro family!
Fine lookin' machine ya got there!
('87 Toro 38150 826)
classiccat is online now
post #20 of 33 Old 02-05-2020, 08:11 AM
Thanks (Given): 16
Likes (Given): 483
wish my powermax was built as well as the old powershift's , the old ones are night and day made better, real machines for hard work not like todays box store grade.
OP's got a 25 year old machine that IS IN better shape than my 3 year old . make me wonder more if the loncin clone motor will be running like that old tech can in another 2 years
GOOD LUCK OP
