Metal Shavings after 1st Oil Change - Snowblower Forum : Snow Blower Forums
post #1 of 27 Old 02-14-2020, 06:35 PM Thread Starter
Likes (Received): 24
Today I changed my oil for the 1st time on my new Toro QZE 821. It was after the first 2 hours
What I did was drained the toro oil I put in it when brand new, then with the oil drain plug out, I poured the rest of the clean toro oil that was left in the container in the fill spout to flush any extra metal shavings out.
After it looked like no more metal shavings were coming out and the oil stopped draining, I put the drain plug back in.
I then switched over to Amsoil 5w30
Picture of oil, then 2 videos. The picture below I had the oil container tilted so most of the oil pooled in the corner.
Videos
https://imgur.com/a/3Ovk3d2
Does this amount of metal shavings look excessive or ok?
Sold Honda HS620 to buy Toro QZR621
Sold Toro QZR 621 to buy Toro QZE 721
Sold Toro QZE 721 to buy Current Toro QZE 821
steeve725 is offline
Likes 2badknees liked this post
post #2 of 27 Old 02-14-2020, 06:56 PM
Thanks (Received): 15
Likes (Given): 32
Likes (Received): 40
Goodness.
johnwick is online now
post #3 of 27 Old 02-14-2020, 06:57 PM
Thanks (Given): 33
Thanks (Received): 66
Likes (Given): 116
Likes (Received): 138
Looks like the oil has gotten water in it
Shovel is online now
post #4 of 27 Old 02-14-2020, 06:59 PM
Thanks (Given): 33
Likes (Given): 116
Look at the other one again.. I saw streaks which look like water.. but if you are seeing alot of metal.. it's not normal
post #5 of 27 Old 02-14-2020, 07:11 PM
Likes (Received): 22
I would definitely keep an eye on it. Some shavings are normal because of the manufacturing process but if you are still getting them after the next change I would be concerned. The pics do look like there is water in the oil but you video looks fairly clean.
BlowerMods1 is online now
post #6 of 27 Old 02-14-2020, 08:03 PM
orangputeh's Avatar
Thanks (Given): 762
Thanks (Received): 235
Likes (Given): 1582
Likes (Received): 1671
i would do another another oil change at the 10 hour mark for peace of mind.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #7 of 27 Old 02-14-2020, 08:16 PM
Thanks (Given): 33
Likes (Given): 116
I would send in the next sample for an oil analysis as well.
They analyze ppm of various metals .. the chunks don't really get counted per say as they aren't is suspension...but it will tell you if your engines is wearing excessively as the oil will be filled with suspended particles.
Likes ST1100A liked this post
post #8 of 27 Old 02-14-2020, 08:56 PM
Pour the oil through a coffee filter, any metal will be left behind.
If I can't fix it, I can screw it up so bad that no one else can either!
Greg13 is offline
post #9 of 27 Old 02-14-2020, 08:59 PM Thread Starter
Already emptied the oil container at auto zone
post #10 of 27 Old 02-14-2020, 09:01 PM Thread Starter
That’d be crazy. I don’t know how that would be possible.
Sealed system, I keep the snow blower in my garage
