Toro CCR 2450 new paddles rub - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 03-01-2020, 02:44 PM Thread Starter
I recently replaced the rubber paddles and lower housing on my CCR 2450. The new paddles rub the lower housing and small sections of the upper housing, although the paddles do spin. Both the paddles and lower housing are OEM parts. I don't see any way to adjust the spacing between the paddles and the housing.
Any suggestions?
zabarnss is offline
post #2 of 6 Old 03-01-2020, 03:01 PM
Thanks (Given): 172
Thanks (Received): 70
Likes (Given): 1217
Likes (Received): 303
Did you remember to transfer over the metal sleeves that go in the holes? That may cause things to move out a bit. Other than that, tight is right. She will wear in...
gibbs296 is offline
post #3 of 6 Old 03-01-2020, 03:07 PM Thread Starter
Yes, I did transfer the metal sleeves.
zabarnss is offline
post #4 of 6 Old 03-01-2020, 04:06 PM
Thanks (Given): 174
Thanks (Received): 342
Likes (Given): 480
Likes (Received): 849
Welcome to the forum!
If you loosen the bolts, can you shift the paddle in slightly, towards center (away from the housing)? I don't remember how much play there was with those bolts, but there's probably a little bit of movement, at least. Even if you can't eliminate the rubbing entirely, if you can shift the paddles a bit to reduce it, the housing will thank you, and the paddles won't get worn down as much for "no reason".
post #5 of 6 Old 03-01-2020, 05:44 PM
Thanks (Given): 63
Likes (Given): 277
Likes (Received): 173
are the housings bent in the areas that rub? Especially near the scraper at the bottom, there is not alot of strength to the housing. You may have to (gently) bend the housing a bit if that is the case. How tight is the fit? Can you turn the paddles by hand through the rubbing areas?
tx
Paul
paulm12 is online now
post #6 of 6 Old 03-01-2020, 07:41 PM Thread Starter
tx
I replaced the lower housing, so it is brand new and not bent. The lower housing is quite stiff and has reinforcing bars in the rear -- I don't think it can be bent. The paddle fit is quite tight -- I can turn the paddles through the rubbing area by hand, but it is tight.
zabarnss is offline
