toro 38080 8/24 - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 03-16-2020, 07:12 PM Thread Starter
toro 38080 8/24
hello i just got a new to me 1986 toro 38080 8/24
this is my first snowblower and i bought it for $100 cad. when i find out how to post pictures i will document my progress.
so far i have done head removal and new gasket and lapping of the exhaust valve and i bought a new carb. The exhaust bolts broke as i was trying to loosen them, the muffler was glowing red after like 5 min of use. so i searched these forums and found out that my exhaust valve needs lapping. so i borrowed a compression gauge. I had 55 psi when i pulled it 6 times. Head bolts came off easy and the cylinder walls looked great to me. so i did a general clean up and lapped my exhaust valve. now i have the head back on and still getting 55-60 psi when pulled 6 times. I researched afterwards and that could be because of the auto decompression mechanism that these engines have. I going to need some help along the way from this forum, I will add pictures and videos when i find out how to do that.
Smithrmark is offline
Likes RIT333 liked this post
post #2 of 11 Old 03-16-2020, 09:05 PM
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 276
Likes (Received): 172
I do not get consistent results measuring compression with the recoil starter. As you mentioned, often the compression release mechanism causes false readings. On the few machines I have had with electric start, the compression measurements seem accurate. I much more trust a cylinder leak-down test. If you have access to one of these testers I recommend it.
A glowing muffler certainly can be valve related, did you measure the valve lash? If the exhaust lash it too small, the valve can stay open and cause the issue.
let us know any progress on this effort, we can help.
Paul
paulm12 is online now
post #3 of 11 Old 03-16-2020, 09:44 PM Thread Starter
I have measured the clearance with a feeler gauge and it had .010 (had tight drag) for exhaust after I did the lapping and .008 for intake (no lapping)
Does anyone know what kind of ignition I have I got a coil that picks up a magnet on the flywheel and sends the spark to the plug.
post #4 of 11 Old 03-16-2020, 10:02 PM
Thanks (Given): 63
Likes (Given): 276
look up your here, with your serial number. Then you can see parts diagrams.
https://www.toro.com/en/parts?Search...tion=equipment
Paul
post #5 of 11 Old 03-17-2020, 11:30 PM
Likes (Received): 1379
More Than Likely It is still a Point Ignition on it.
post #6 of 11 Old 03-18-2020, 06:03 PM Thread Starter
toro 38080 8/24-89977995_10163285097060416_319282401291272192_n.jpg
toro 38080 8/24-90050327_10163285097150416_5564359620660559872_n.jpg
toro 38080 8/24-90192796_10163285097680416_4210732799663013888_n.jpg
toro 38080 8/24-90292976_10163285097815416_329656001441562624_n.jpg
toro 38080 8/24-90304550_10163285097440416_5321299260942057472_n.jpg
toro 38080 8/24-90012288_10163285097195416_1517794068917125120_n.jpg
toro 38080 8/24-89958769_10163285097655416_8749227769298157568_n.jpg
post #7 of 11 Old 03-18-2020, 06:05 PM Thread Starter
i have a 1986 and i do not see a wire coming from my "points" to the high voltage air coil that does to the spark plug.
how do i post videos do i have to post it to youtube first?
post #8 of 11 Old 03-18-2020, 06:17 PM Thread Starter
I have play in my worm gear Fore and aft
I have play in my drive pulley
And my third gear speed wonít engage on the gear shift position
Those are all the problems I have now
The augur drum has no play
Are these symptoms normal?
post #9 of 11 Old 03-20-2020, 08:50 AM Thread Starter
how bad is this?
what do i need to do to fix it?
is it worth fixing ? ( this is my first snowblower )
thanks for the help
post #10 of 11 Old Today, 01:08 PM
Thanks (Given): 169
Thanks (Received): 68
Likes (Given): 1209
Likes (Received): 293
She appears to be a bit mangled by the previous repair guy. Summer is coming, everyone is broke or not working. You might be able to find a machine with a better housing that you can drop your motor on for next to nothing. Good luck!
gibbs296 is online now
