Toro 724 drive pulley info - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 02-08-2014, 06:07 PM Thread Starter
Toro 724 drive pulley info-724-wheel.jpgHello all,
I have a toro 724 model 38072. I believe its a 1995 model. I have the machine apart doing a motor rebuild. While removing the engine, I found that the drive pulley for the trans( not the impeller) was very loose. I removed the u-shaped bracket from the within the trans area which also contained the metal wheel that the friction disc contacts. I removed the four little bolts that hold the adapter to the u-shaped bracket. In addition I removed a snap ring located on the shaft. It appears from the toro diagram that a bronze bushing and bearing are available separately but I cant seem to figure out how to disassemble this thing
thanks in advance
Hagamatic is offline
post #2 of 3 Old 02-08-2014, 11:44 PM
Is there a bolt in the belt pulley side or underneath the pulley between everything on the collar? If not I'm wondering if its pressed together.
3 Ariens 522 Single Stage
Toro 3521 Repowered with a 6.5hp
Craftsman 521 (selling)
other toys
Troybuilt Horse 70s or 80s model
Troybuilt Econo-horse
John Deere Jx75
John Deere Js46
John Deere 111
and a few other parts machines.
Colored Eggs is offline
post #3 of 3 Old 02-09-2014, 04:09 AM
Likes (Received): 1380
Thumbs up
that is pressed in there. take it into a shop to remove and reinstall. ALOHA to the form.. MAHALO:c ool:
