Engine might rev high, might stall. - Snowblower Forum : Snow Blower Forums
post #1 of 2 Old 02-09-2014, 11:21 PM Thread Starter
Hi. First post. I have a Toro CCR 1000 form 1994 or so. Sometimes the engine will really rev high. Like it's going to explode. Sometime it will just stall. But it will always start right back up. Spark plug is 4 years old BTW.
Other issue is sometime the electric start will not engage. It makes noise, but isnt turning the engine. This has happened twice, and both times I have taken it in the basement and the starter works.
Appreciate any and all input. Thanx.
ID:	11321   Click image for larger version
93pa is offline
post #2 of 2 Old 02-09-2014, 11:56 PM
For the starter you will have to remove it and clean the shaft the gear spins on with some spray to get the old hard dirt, grease and rust off. Then put a few drops of motor oil or something on there.
