oil leak - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-23-2014, 07:49 PM Thread Starter
oil leak
Hi. Newbie here but I have a question about an oil leak. I have a 2 year old 8 26 oxe toro snowblower. It looks to be leaking at the oil fill tube. I didn't take it apart yet wanted to see if anybody had this problem. thanks in advance
jdjm is offline
post #2 of 5 Old 02-23-2014, 08:26 PM
Likes (Given): 1887
Likes (Received): 665
hello jdjm, welcome to SBF!! i don't have an 826 oxe but sometimes when i unloosen the dipstick on the 521 the tube will rotote, check yours to see if its loose
post #3 of 5 Old 02-23-2014, 08:30 PM
On many new style motors you fill until the oil is level with the fill cap at the base of the motor (not the dip stick tube). The caps don't seal well so if you overfill a little you will get a little oil that finds its way out in time. I'm not sure if this relates to you but it is not uncommon.
scipper77 is offline
post #4 of 5 Old 02-24-2014, 10:52 AM
This happens to me all the time as well on my 521. No matter how tight I try to get it, it still manages to come loose again over time. I would try tightening the tube up as much as possible and see if it still leaks.
Toro 521 (38052C)
Made in Canada.
ToroGuy is offline
post #5 of 5 Old 02-24-2014, 05:45 PM
Likes (Received): 1383
Thumbs up
the o-ring might have gone bad.. slap a new one in there. let me know:coo l:
