Briggs spark plugs - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 03-25-2014, 12:10 AM Thread Starter
enigma-2's Avatar
Thanks (Received): 21
Likes (Received): 51
Briggs spark plugs
I have a Toro CCR 3650 and finally getting around to putting some money into it (new blades, scraper bar, belt & spark plug). Blades look worn, probably a little more than an inch gone at the center, maybe a little more. Wear indicator long gone. Scrapper just a few threads of plastic left. Amazing how fast they wear out. Only been eight years.
Anyway, parts are readily available - except for the spark plug!
Briggs & Stratton engine, Toro (Briggs) p/n 108254 plug, but no one, no one, including Briggs seems to carry it. Only substitute I could reference was a NGK BRMR4A, which also does not exist.
I was eventually able to find it and order it from www.eReplacmentparts.com for a little over $8 (includes s/h).
Anyone else had this problem? Did Briggs discontinue making spark plugs?
Couldn't find any cross-reference to Champion or any other brand.
2014 Ariens 24" Platinum
Toro CCR 3650 GTS
enigma-2 is offline
post #2 of 3 Old 03-25-2014, 12:24 PM
Should be able to use a champion RCJ8Y.
http://www.justanswer.com/small-engi...pion-home.html
Ryan is offline
post #3 of 3 Old 03-25-2014, 02:35 PM Thread Starter
enigma-2's Avatar
Thanks Ryan. I called a local dealer and he told me that you are correct, the B&S plug is made by Champion (or NGK) and he stocked the RCJ8Y. So next time I'll know.
I spent a couple of hours looking for a correlation between B&S and Champion, found sites that did cross-reference but for that particular B&S plug only listed the NGK BRMR4A (which I could not find on any suppliers site). It was getting late so I bit the bullet and bought the B&S.
Thanks again.
Toro CCR 3650 GTS
enigma-2 is offline
