Toro 622 model 38062 - Snowblower Forum : Snow Blower Forums
post #1 of 19 Old 09-27-2014, 08:44 PM Thread Starter
How's it going ? I bought a toro 622 model 38062 for $20 and didn't start which guy told me ( he said could use service ). This looks like model from 98 approx. Tried to start a few times , changed gas & spark plug with no go.
Took to a repair place and they said I need a new Carb and a service. It was there for 2 weeks yet took only 10 minutes to Check. ( called 10 mins before call back as he had machine on table today ). Price they said was $250 total.
I really don't want to this much into machine that's 16 yrs old or so .... Would a repair kit for like 15$ or so be sufficient to fix this issue or anything else it could be ? I've seen carbs for approx 135$ which I'm still iffy on , is it basic swap out n swap in ?
Thanks in advance.
Sf49168 is offline
post #2 of 19 Old 09-27-2014, 10:21 PM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
I guess the bigger question is, how mechanical are you and do you have the ability to post pictures? Most of us here, can walk anybody through most things.
post #3 of 19 Old 09-27-2014, 10:36 PM
Grunt's Avatar
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3328
Likes (Received): 677
"IF" the carb is the only problem, they can be purchased for as little as $35 on eBay.
If the carb is in decent condition, a rebuild kit ($9 P/N 31840) and a good cleaning may be enough to get it running. I assume the shop found numerous things to repair for $250.
post #4 of 19 Old 09-28-2014, 07:03 AM Thread Starter
Thanks for reply , I'm pretty mechanical useful , just never did a carb before. The shop said a carb and regular service was 250$ so not sure what they found.
Cheapest compatible carb I saw was 75$ on eBay. ( my serial is 7915197, 1997 unit )
May try to and get rebuilt kit and try that , worst case ill look for new in upcoming months but rather not since I bought machine for $20
Thanks again
Sf49168 is offline
post #5 of 19 Old 09-28-2014, 11:14 AM
Grunt's Avatar
Thanks (Given): 275
Likes (Given): 3328
Will the engine start if you pour a little gas into the spark plug hole ? If yes, then you at least have a working ignition system. Below are some links that will help getting the machine running again. If you have any problems along the way, there are some great people here that are willing to help.
Tecumseh engine service manual-
http://www.barrettsmallengine.com/manual/tecumsehlheadmanual.pdf
Carb Cleaning Series-3
http://outdoorpowerinfo.com/repairs/tecumseh_carb_632334a.asp
http://outdoorpowerinfo.com/repairs/tecumseh_carb_632107.asp
Tecumseh carb kit Part Number-
31840
post #6 of 19 Old 09-28-2014, 11:51 AM
Thanks (Received): 379
Likes (Received): 1377
31840
GRUNT is the man 4 those tecumsapart engine questions.
post #7 of 19 Old 09-28-2014, 12:48 PM Thread Starter
31840
To be honest I havent tried the gas in spark plug hole as machine still at shop. Maybe the tried at shop to pin point carb is bad ?? I am picking up this week and will try that and go from there. Hopefully I can fix otherwise its not like it broke the bank. I will keep all posted.
Sf49168 is offline
post #8 of 19 Old 09-28-2014, 06:01 PM
db9938's Avatar
Another recommendation, try using a ultrasonic jewelry cleaner, with a drop of dawn and tap water. Works pretty amazingly, without the fumes.
You'll have to break the fuel bowl down, and the butterfly plates, but those are pretty simple things. Make sure to take pictures as you go, so that you have references.
post #9 of 19 Old 09-28-2014, 10:02 PM
Grunt's Avatar
Thanks (Given): 275
Likes (Given): 3328
When we were kids mounting horizontal shaft engines on bicycles with a large fan belt like factory built Whizzers, we used to remove any plastic or rubber parts and throw the carb into a pot of boiling water for a few minutes. Anyone else ever do this??
post #10 of 19 Old 09-28-2014, 10:23 PM
db9938's Avatar
I've done it with machine gun parts. Does that count?
