What auger box lube for a 1978 826? - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 10-25-2014, 10:51 PM Thread Starter
jeepguy03's Avatar
Likes (Received): 7
I've read a few threads about some GF-5 gear oils being harmful to the brass gears inside the gear case for the augers.
I have some Red Line Synthetic 75w90 left over from my Jeep, and some Ariens L3 gear box lube left over from a neighbor's Ariens that I serviced. The owner's manual for my machine says to use a 90 weight EP transmission oil.
What should I use? I also picked up a Toro 624 as a project and plan on changing the oil in that gear case as well.
Thanks!
1984 Toro 724 - 7.75hp Briggs Intek OHV repower >> restoration project
2007 Toro CCR Powerlite - 3hp Tecumseh 2-stroke
1971 Gravely Super Convertible 7.6 - 30" mower, snow blade
2005 John Deere G110 - 54" mower, 42" snowblower
jeepguy03 is offline
post #2 of 10 Old 10-26-2014, 10:43 AM Thread Starter
jeepguy03's Avatar
Likes (Received): 7
Ariens also sells part# 00006000 which is SAE 90 weight MP gear oil. What is the difference between EP and MP? Would this be suitable to use? The Ariens dealer is right down the street from me.
post #3 of 10 Old 10-26-2014, 11:46 AM
Likes (Given): 215
Likes (Received): 304
First off, I don't know. I hope somebody here can be more help.
Some Googleing found here says
API stands for Americam Petroleum Industry and GL stands for Gear Lubricant, see below for their definitions:
API GL-1 Straight mineral oil.
API GL-2 Mild EP for worm gear oils.
API GL-3 Mild EP for spur and spiral bevel gears in axles and transmissions.
API GL-4 Medium EP, moderate severity hypoid gears, manual gearboxes.
API GL-5 High EP, all hypoid axles, some manual gearboxes.
API GL-6 Extra high EP, now obsolete.
Wikipedia says
EP additives which contain phosphorous/sulfurous compounds are corrosive to yellow metals such as the copper and/or brass used in bushings and synchronizers;
and
Also, transmissions which explicitly call for GL-4 oil may have been designed around this lower concentration of EP additives and thus may contain yellow metal parts which GL-5 will corrode.
dbert is offline
post #4 of 10 Old 10-26-2014, 11:53 AM
Likes (Given): 215
dbert is offline
post #5 of 10 Old 10-26-2014, 12:16 PM Thread Starter
jeepguy03's Avatar
Likes (Received): 7
Yes it does seem to contradict it which is why I'm confused. I guess my question would be which era Ariens is closest to the gear case used on my Toro? That would allow me to find out which oil is appropriate. It sounds like the Ariens gear oil 00006000 is the closest match, since it is what is recommended for the older machines.
post #6 of 10 Old 10-26-2014, 05:40 PM
Thanks (Received): 379
Likes (Received): 1377
Use 80-90 or 85-95 Non synthetic gear oil. the seals will not hold the syn stuff. ANY BRAND NAME WILL DO....
post #7 of 10 Old 07-04-2018, 12:19 AM
Thanks (Given): 7
@POWERSHIFT93
My toro 828 OXE manual says to use
If the oil level is low, add GL-5 or GL-6, SAE 85-95 EP gear oil lubricant to the gearbox until the point of overflow.
Note: Do not use synthetic oil
Is 80W-90 an acceptable substitute for 85-95 EP? (non synthetic, of course)
example:
https://www.autozone.com/greases-and...32-oz/693858_0
I don't know what is in the gearbox right now - should I just drain it completely then add the new stuff?
boobird is offline
post #8 of 10 Old 07-04-2018, 04:33 AM
Originally Posted by boobird View Post
@POWERSHIFT93
example:
Drain it oot and add 80-90 OR 85-95 Stuff.
Thanks boobird thanked for this post
post #9 of 10 Old 07-04-2018, 06:40 PM
Thanks (Given): 7
@POWERSHIFT93
Thanks.
I tried to tilt the machine forward to drain out any oil, but nothing came out. The plug itself had a thick black residue at the base of the plug
The manual says to keep the machine on a level surface. Since the plug is located 1/2 way up the gearbox, this means the oil won't be filled to the top. Is this correct?
I tried to squeeze as much as I could while the 4 wheels were level on te ground. But most of it oozed out..
boobird is offline
post #10 of 10 Old 07-05-2018, 01:21 AM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 183
@POWERSHIFT93
correct
MY VIDS ON FIXIN HER UP
vinnycom is offline
Likes boobird liked this post
