Belts for 824 - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 11-13-2014, 12:00 AM Thread Starter
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
Belts for 824
I need to replace the belts on my 824 and the previous owner put Kevlar belts on it. One had quite a deep break in it. The Toro belt spec'ed is a conventional rubber v belt.
I suppose they don't make all that black dust. Do they grip as well in the cold?
I don't know of any snow thrower that comes with Kevlar but I am far from an expert.
I know Kevlar is suppose to be stronger but on a snow thrower is it really an advantage on a snow thrower?
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #2 of 6 Old 11-13-2014, 03:46 AM
Likes (Given): 1885
Likes (Received): 663
why wouldn't the toro belts grip / work as good as the Kevlar belts, toro belts have been around much longer
post #3 of 6 Old 11-13-2014, 04:56 AM
Kevlar works fine on my Ariens. The stock Toro belts are sure to have something in them other than basic rubber.
post #4 of 6 Old 11-13-2014, 02:21 PM
Likes (Received): 1383
the TORO OEM belts are your best bet.
post #5 of 6 Old 11-22-2014, 03:42 AM
Thanks (Given): 30
Thanks (Received): 40
If you want to buy your belts locally I would favor tractor supply over at auto parts store. I would expect that quality of the belts would be better for the constant load. I am on the coast and I get heavy wet snow the strongest, grippiest available is the only one I would consider ;-)
1991 Toro Powershift 824 with impeller mod (running 94 AvGas )
Pathfinder13 is offline
post #6 of 6 Old 11-23-2014, 11:43 PM Thread Starter
Thanks (Given): 67
Likes (Given): 115
Pathfinder13, Thanks. I found my local NAPA carries Utility V-belts in both the 3L and 4L profile. The Napa belts are made by Gates whose quality I won't fret over. I don't believe they are Kevlar as I would assume they would say so, and they don't. I am going to buy some Kevlar back ups on line.
Thanks for suggesting Tractor Supply. It is a bit of ride for me to get to one but good to know.
Where do you get your Av Gas?
Current machines
Ariens 926LE
