First Snow-blower Purchase - Z518 - Stupid Questions - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 11-16-2014, 04:23 PM Thread Starter
Hey everybody!
I live in NE Ohio and have never bought or used a snowblower before. I am not mechanically inclined at all (we don't even own a lawnmower - we pay our neighbor to do the grass if that's any indication) but I decided to bite the bullet and look into getting some kind of machine to get through the winter.
I bought a Z518 at Home Depot yesterday - it seemed very well reviewed and it fit our budget. Plus I like the light weight and compact size.
I got it all set up today and the very first time I started it, there seemed to be a lot of exhaust coming out. The engine also seems to be running kind of rough, more jumpy and hitchy than a lawnmower engine.
I used the oil that came with the machine, and 89 octane gas (purchased yesterday). I let it run for probably 3-4 minutes tops. Is there anything I could have done wrong in the setup, or is this expected behavior for a very fresh single-stage machine?
Thanks for your help.
mwisebaker is offline
post #2 of 12 Old 11-16-2014, 04:28 PM
Likes (Received): 1383
did you put oil in the gas??????
post #3 of 12 Old 11-16-2014, 04:31 PM Thread Starter
I did not. Was I supposed to?
post #4 of 12 Old 11-16-2014, 04:37 PM
no you are not suppose to. you filled the crank case with oil right. if u can post a vid of what is going on there. it is a toro am I correct on that.
post #5 of 12 Old 11-16-2014, 05:02 PM Thread Starter
I put oil in and checked it with the dip-stick according to the manual.
Here is a video of what is happening.
post #6 of 12 Old 11-16-2014, 05:04 PM Thread Starter
Only other thing I'll note here is that I did not use the electric start feature but I used the pull start.
post #7 of 12 Old 11-16-2014, 05:06 PM
pwm
Looks to me like the choke is on full. If so, turn the choke off after it get running.
pwm is offline
post #8 of 12 Old 11-16-2014, 05:15 PM
https://www.youtube.com/watch?v=kEVC...ature=youtu.be
turn the choke off let it run full throttle for a couple of minutes. then every thing should be fine. any more questions let me know.
post #9 of 12 Old 11-16-2014, 05:34 PM Thread Starter
AHA! YES! That made it much better!
And after consulting the manual I see that it was mentioned there, I just overlooked it.
Glad it was a simple fix and I came here before the first time I tried to use the thing!
Thanks for the quick responses!
post #10 of 12 Old 11-16-2014, 05:40 PM
that is what we are here for.
