Toro 624 power shift - new engine - Snowblower Forum : Snow Blower Forums
post #1 of 101 Old 11-18-2014, 11:56 PM Thread Starter
Hi all. I have a 1988 toro 624 power shift here m#38510. Last year the governor broke and it raced itself to an early demise. I see the threads on using the hf 69730 6.5hp engine, which appears to be a good replacement for the Tecumseh H70 series engine. Mine has an H60 engine. Does anyone know if it is physically the same as the h70? Dr Google isn't clarifying it for me lol.
Thanks-
Bonzohansen is offline
post #2 of 101 Old 11-19-2014, 01:15 AM
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
Thanks-
Same mounting bolt hole pattern as the Tecumseh 7hp engine. Is your engine a 2 shaft engine or a single shaft?
GustoGuy is offline
post #3 of 101 Old 11-19-2014, 05:06 AM
Yea, H60 and H70 are same block. Most parts can be swapped between the 2 engines and I did take one broken H60 and one broken H70 and make 1 working engine.
As was stated, just make sure yours is a single shaft.
post #4 of 101 Old 11-19-2014, 07:20 AM
Likes (Received): 9
I just got done replacing the exact model powershift with a 6.5hp harbor frieght clone. I will tell you this - the mounting studs for the engine are the same as the H60 but the shaft is way too short. before really thinking through the swap I ground off the mounting studs and drilled new holes closer to the impeller. only one problem...on this machine there is no way to put the bolts in from under the machine because of the transmission and all the stuff that makes this machine powershift.
I finally got mine mounted by using L-bolts from the top and setting the engine over them carefully so as not to drop them below. overall massive pain in the butt to swap this machine with a clone engine. after I got the new engine mounted then came the issue of the belts lining up correctly so that the new pulleys, particularily the transmission pulley, didn't stayed engaged all the time. The alignment of the shaft from the clone engine to the H60 is different and the belt would stay engaged on the pulley no matter what size belt I used. the answer?? I had to make my own belt gaurds and try and gerry-rig this to take tension off the belts. yes, it worked finally, but I don't have much confidence in the final solution.
moral of this story - do a lot of research and buy a engine that has the correct shaft length and mounting holes otherwise you are in for a lot of work.
Current machines-
1995 Honda HS 621
Buttchet is offline
post #5 of 101 Old 11-19-2014, 04:38 PM
Likes (Received): 1383
on second thought I am leaving this one ALONE!!!!
post #6 of 101 Old 11-19-2014, 10:02 PM Thread Starter
Thanks guys. It is a single shaft. I kept coming up with h70 references so I wasn't sure.
I'll do more searching and reading, I haven't seen the troubles listed by buttchet before.
post #7 of 101 Old 11-19-2014, 10:12 PM
you could also try grinding off the paint where the motor mounts and welding on studs to mount the motor on
post #8 of 101 Old 11-19-2014, 10:32 PM
Likes (Received): 9
I'm not sure what POWERSHIFT93 used to repower his Toro but I would look into that model briggs - more money for sure but might be worth it versus the trouble. also have to figure the pulley will not fit on the Harbor clone as it is 3/4" shaft versus the Tecumseh 7/8".
Current machines-
1995 Honda HS 621
Buttchet is offline
post #9 of 101 Old 11-20-2014, 10:25 AM Thread Starter
I'd look into another engine if the price is reasonable. The predator engine at HF (which is 5 miles from my house) is the one i keep coming up with when I search. I'm not looking to drop $500 on a 26 year old machine I can replace for $1000
post #10 of 101 Old 11-20-2014, 02:20 PM
you know what I used is a 13HP BRIGGS engine. for THE MASTERPIECE.:c ool:
