Toro 522 issue with idle - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 11-19-2014, 10:48 AM Thread Starter
It has the fixed jet carb so I am not sure how to fix an idle issue. When I initially start up it runs nicely. When I engage the auger there are no issues. I get the the end of my driveway on the first pass and it starts to run funny. It won't throw snow efficiently and gets clogged easily. I am only going through about 6 inches of snow and it is not terribly heavy.
So far I have replaced the carb as the old one was very dirty and it was cheap to put a new one on. I also replaced the spark plug as I didn't know how old it was.
Not really sure what else I can do. Any ideas?
huwge23 is offline
post #2 of 9 Old 11-19-2014, 11:06 AM
Likes (Given): 1887
Likes (Received): 666
hello huwge, welcome to SBF!! have the belts been changed
post #3 of 9 Old 11-19-2014, 01:49 PM Thread Starter
Thank you and no I have not that make good sense though. I will give that a try.
huwge23 is offline
post #4 of 9 Old 11-19-2014, 03:51 PM
Likes (Given): 1887
my 521 started running funny just before the belt broke, seeing that it apart may as well change both belts that way you'll know how old they are
post #5 of 9 Old 11-19-2014, 03:59 PM
Likes (Received): 1383
CHECK the impeller bearing also. ALOHA to the forms.
post #6 of 9 Old 11-19-2014, 04:21 PM Thread Starter
I will do that as well. I am also suspecting the 5hp is not enough to get through the snow we are dealing with in Buffalo right now.
huwge23 is offline
post #7 of 9 Old 11-19-2014, 04:48 PM
Likes (Given): 1887
take your time in first gear and don't over work the machine
post #8 of 9 Old 11-19-2014, 04:51 PM
my toro 824 38080 started doing that, replaced the carb 3 times thinking the ones they sent me were bad, turned out to be a leaking exhaust valve. i said screw it, and just replaced the engine with a 196cc honda clone, no problems yet
post #9 of 9 Old 11-19-2014, 06:15 PM Thread Starter
I haven't gone over first gear at all and can't go more than a couple feet at a time. It just seems to clog too easily.
huwge23 is offline
