1128 adjustments Blower drive - Snowblower Forum : Snow Blower Forums
post #1 of 24 Old 11-25-2014, 10:33 PM Thread Starter
Thanks (Given): 112
Thanks (Received): 78
Likes (Given): 354
Likes (Received): 157
We have 6 in of wet snow the Toro blows better than I thought it would. But some times when I want to change the direction of the chute the blower drive on right bar will not stay engaged. Is there a quick fix or adjustment, It is still snowing like mad will have 4 to 6 in tomorrow for sure. Thanks
Hanky is online now
post #2 of 24 Old 11-26-2014, 12:21 AM
Likes (Given): 7
have you give a better description......no idea what your problem is
RoyP is offline
post #3 of 24 Old 11-26-2014, 09:27 AM Thread Starter
Thanks (Given): 112
Likes (Given): 354
I am going down my drive and after I get past my house I want to changr direction of the chute so I use my right hand to move the Joy stick and the augar stops not all the time just every 3 or 4 time With 6 in of wet snow this is a pain. Just looked out side and have 8 in of more wet snow.
Hanky is online now
post #4 of 24 Old 11-26-2014, 01:53 PM
You are going to have to look under the dash and figure out how the locks work and then see if something is worn out or what.
post #5 of 24 Old 11-26-2014, 06:18 PM Thread Starter
Thanks (Given): 112
Likes (Given): 354
Thanks looked and looks good played with it and appears to of fixed it self, machine is new, good thing got 12 in of heavy wet stuff this morning.
Hanky is online now
post #6 of 24 Old 11-27-2014, 05:18 AM
Thanks (Given): 13
Likes (Given): 54
Likes (Received): 19
Let me know if you run into this again. I'll do some looking around!
MagnumB is offline
post #7 of 24 Old 11-27-2014, 08:19 AM Thread Starter
Thanks (Given): 112
Likes (Given): 354
Thanks MagnumB, my joy stick is sticky a lot of the time now could be the volume of wet snow going out the chute it does not want to turn some times. I will not worry much for now in case we get more snow.
Hanky is online now
post #8 of 24 Old 11-28-2014, 04:41 AM
Thanks (Given): 13
Likes (Given): 54
That's strange, generally speaking back in around 2006, if you were to have an issue with the quick stick, it would be due to water freezing in the lines. This has been largely solved. If you are having issues with rotation, because it's a floating chute mechanism, then perhaps the issue then is with the joystick interlock (blue dealy on the top of the stick)
Wondering if it's not fully disengaging...then again, that's likely to affect both axis of movement.
Is your unit stored indoors or out?
The cables are all pre stretched...so that shouldn't be an issue.
If you can post a vid showing the issue that could help. For the most part the common complaint (if you can call it that) is that it's too easy to move. It's a measure of it's good design that under load, the system frees up.
I'm curious as to the problem. Either way, it's certainly solvable.
Mag
MagnumB is offline
post #9 of 24 Old 11-28-2014, 08:33 AM Thread Starter
Thanks (Given): 112
Likes (Given): 354
Thanks Mag, talked to the dealer yesterday, they will come over and take a look at it. I keep the Toro in a unheated garage.
Hanky is online now
post #10 of 24 Old 12-14-2014, 07:04 PM Thread Starter
Thanks (Given): 112
Likes (Given): 354
Got to take the 1128 HD to the dealer the interlock is not working. we are not to get any snow for 3 days.
Hanky is online now
