97 power shift 824 questions - Snowblower Forum : Snow Blower Forums
post #1 of 26 Old 11-25-2014, 10:54 PM Thread Starter
Ok so I got this blower from my gfs dad, he said if you can get it running I can have it, sweet lol. Ok so I'm new to these, my dumb question is, shouldn't it be able to roll on its on ? When I picked it up I had to drag it cause the wheels won't move ? What could it be ?
AceMan is offline
post #2 of 26 Old 11-26-2014, 05:38 PM
Thanks (Received): 379
Likes (Received): 1377
are the wheels rusted to the axle?????? why don't you upload a video of this problem that is presenting itself. that way I can better help you. ALOHA to the forms..: cool:
post #3 of 26 Old 11-26-2014, 06:12 PM Thread Starter
No nothing is rusted, I took the tranny apart an somebody put so much grease in there that it wouldn't go into nutruel. So I cleaned out all the grease, cleaned off the gears an put it back together. Seems to be working now. Now I just have to figure out why when it's running an I put it into gear it moves without having the handle down.
AceMan is offline
post #4 of 26 Old 11-26-2014, 06:51 PM
what kind of grease did you use??????
post #5 of 26 Old 11-26-2014, 06:54 PM
then there is some thing wrong with the transmission. the only way it should move is when the handle is down. the transmission is out of adjustment that is what's wrong with it.
post #6 of 26 Old 11-26-2014, 08:24 PM Thread Starter
It's a low temp grease, can't remember what it's called.
AceMan is offline
post #7 of 26 Old 11-26-2014, 08:24 PM Thread Starter
What do I need to adjust ?
AceMan is offline
post #8 of 26 Old 12-04-2014, 04:37 PM Thread Starter
Bump
AceMan is offline
post #9 of 26 Old 12-04-2014, 07:26 PM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
I don't have that machine, and have never worked on one. But have you downloaded the owners manual from toro?
From a general standpoint, either the cables from the handles levers are out of adjustment, or you could be looking at a more entailed job with a problem with the drive mechanism. My gut hunch, I'm betting on the second.
post #10 of 26 Old 12-05-2014, 04:59 AM
Thumbs up
the transmission is sealed from the little TORO factory. it is called lubiplate mag 1 grease. in order to adjust the trans. put it up on the bucket. make sure there is no gas in the tank. otherwise you will have a hazmat problem on your hands. there are 4 bolts that hold the trans in. back them out until the trans slides around. there should be no more than 3/8 chain slap in it. check to make sure that is right. I am going off the top of me little mind on that one. then tighten them up. upload pics or a video so I can see everything and to become 1 with that machine. let me know the score on that.
