Fuel type / recommended additives in an older Toro - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 12-22-2014, 10:05 PM Thread Starter
Likes (Received): 26
Hello,
Instead of asking this question in my other thread (regarding my 1980's Toro 826 model 38150), I thought I'd post it as a new thread. I believe it merits it's own discussion.
In essence, I would like to know what fuel type should be used in an older Toro machine: standard (87 octane), mid-grade (89 octane) or super (91 octane)?
Also, based on research I've done when I bought an outboard motor for my boat, I know you're not supposed to put anything with Ethanol in it because it will gunk up the carburetor... but are there any recommended additives to put in the fuel of an older snow blower, other than fuel stabilizer for long term storage?
Personally, I often put Lucas Upper Cylinder Lubricant in my fuel, both for my truck and the small engines I own. So far, I haven't seen any negative side-effects and I like the idea of "lubing the cylinders" when the engines run, lol! On the truck it actually seems to reduce fuel consumption a little bit, as advertised.
762mm is offline
post #2 of 14 Old 12-22-2014, 10:12 PM
Thanks (Received): 147
Likes (Given): 215
Likes (Received): 305
I started using Sea Foam about two years ago and have become a convert. At 1 oz per gallon of gas, one can will last me a year for mower/blower/trimmer etc.
dbert is offline
post #3 of 14 Old 12-22-2014, 11:04 PM
Likes (Received): 9
I use Lucas and a product called Star-tron. been very happy with both and have no problems over the last two years. cheap insurance in my eyes. I put in high octane as long as I have the two additives and my equipment runs great
Current machines-
1995 Honda HS 621
Buttchet is offline
post #4 of 14 Old 12-22-2014, 11:53 PM Thread Starter
I was thinking about SeaFoam too at one point, but I always thought of it to be best for de-carbonizing the air intake on a car / truck. Lots of smoke!
That being said, I usually try to stay away from "one solution for all problems" type of products. Perhaps SeaFoam is the exception to the rule though, I haven't really tested it.
As for Lucas, they advertize their upper cylinder lubricant as both a lubricant and crud remover / injector cleaner, so I lean more towards that. Personal preference, of course... then again, I was told that adding a bit of 2-cycle oil to the gas can accomplish the same effect (lubricate cylinders in a 4-stroke engine), but for much cheaper than the Lucas stuff.
762mm is offline
post #5 of 14 Old 12-23-2014, 06:59 AM
Likes (Given): 1887
Likes (Received): 666
i think most use 87 octaine gas but i have a habit of using mid-grade in everything thats gas powered with some seafoam added
post #6 of 14 Old 12-23-2014, 08:54 AM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2045
Likes (Received): 517
octane (resistance to detonation) degrades over time so I always use 93 for my small engines especially if the gas may sit in the can for 1-2mos. Stabil gets added as soon as I get home.
Also add seafoam (dilutions above is < 1%.) especially with these old L-head engines which love to coke-up the valves/seats & head...this is a preventative.
If your machine is already coked-up (check through the plug-hole), you're going to want to do a decarb.
At a minimum, run a tank full of 10% seafoam...and when it's almost gone, spray some pure seafoam into the carb air intake and cut the engine...then spray some seafoam directly into the cylinder and let it sit for 15-20min. Now make your neighbors happy and fire that baby back-up with fresh gas .
Lately I've been pulling the heads and cleaning the coke using seafoam and a nylon brush...then reseating/lapping the valves. A 3.5hp machine that I thought was clean after the seafoam decarb above was still pretty gunked-up.
I've had RPMs (and power) jump after a good cleaning...so check your RPMs to make sure you're not over-revving.
('87 Toro 38150 826)
classiccat is online now
post #7 of 14 Old 12-25-2014, 05:56 PM Thread Starter
Thanks for the detailed how-to on a snowblower SeaFoam treatment! I'll definitely try this after the Holidays... my snowblower could reportedly be a 1975-1977 model, so that's a lot of potential crud accumulation in that Briggs engine!
762mm is offline
post #8 of 14 Old 12-25-2014, 06:04 PM
Likes (Received): 1383
use 87 non-oxy gas if you can find it.
post #9 of 14 Old 12-30-2014, 05:54 AM Thread Starter
Hey everyone,
After doing some reading about the different fuel types to use in small engines, I came across information that apparently all gas will eventually gunk up your carburetor and possibly other parts in a small engine because of the general accepted use of Ethanol in today's gasoline. In essence, it produces a varnish-type deposit that's a b*tch to clean. This is why it is (apparently) recommended to buy specialty gas at marinas or other small engine places that has zero ethanol added, usually at a very big premium... because it will keep your small engine and carburetor alive much longer. Hmm... interesting.
Well, that being said, I decided to make some inquiries about local gas (via Google searches / websites of different suppliers) and ethanol is indeed widely used in all gasoline grades, with the maximum general content of up to 10% (known as E10). The suppliers do not have to identify it as such, as long as they do not exceed 10% ethanol per volume of gas. Higher ethanol content has to be legally identified as ethanol gas though (E15 for 15%, etc).
In sum, all gas suppliers use it and it seems like my small engine on my new (used) Toro is indeed doomed down the line... all but one. Apparently, Shell's V-Power 91 octane gas DOES NOT contain any ethanol whatsoever, plus includes a cylinder lubricant already in it. And of course you can get it at any Shell station, no need to pay the premium at the marina (that probably gets their gas at Shell too). Here's the info I got off Shell Canada's website:
2. Is Shell V-Power premium gasoline safe for all vehicles?
  • Shell V-Power is effective in all gasoline-powered engines found in conventional, modern and hybrid vehicles as well as motorcycles, snowmobiles, and leisure marine vehicles.
  • Tested in today’s advanced turbo-charged and direct injection engines, Shell V-Power helps resist thermal breakdown at high temperatures, actively protecting against gunk under tough engine conditions.
  • Shell V-Power premium gasoline in Canada does not contain ethanol.
Well, I guess I answered my own question. From now on, my mower, boat engine, gas chainsaw and my Toro snowblower will only feed on Shell's V-Power 91 octane and no need for extra additives (because everything's already mixed in the gas). I used it in the truck a couple of times in the past whenever gas was cheap(er) (because it supposedly removes gunk) and, as advertised, it actually gave me better mileage than gas from other places... so it'll probably have some beneficial effects on a smaller engine too.
Zero ethanol is a definite winner here.
762mm is offline
post #10 of 14 Old 12-30-2014, 08:16 AM
Thanks (Given): 231
Likes (Given): 2045
you'll appreciate this link: PureGas
