Added some front weight to the new 1128 OXE Power Max HD today! - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 12-23-2014, 01:44 PM Thread Starter
Well Hanky did but I am the photographer! This is a 1"x1" solid piece of steel that is 25" long! It weighs roughly 7lbs. It should help a bit!
ZippoMan is offline
post #2 of 13 Old 12-23-2014, 02:07 PM
Thanks (Given): 112
Thanks (Received): 78
Likes (Given): 354
Likes (Received): 157
This was done to help hold the front down a bit for the EOD snow that the town leaves behind. Looking after 3 driveways this should make it a lot easier.
Hanky is online now
post #3 of 13 Old 12-23-2014, 02:12 PM
Thanks (Received): 123
Likes (Given): 43
Likes (Received): 899
Should also make the skids wear nicely and even.
Coby7 is online now
post #4 of 13 Old 12-23-2014, 03:34 PM
Likes (Received): 82
Hank, I added some front weight also yesterday with a 1/2" X 27"X 4 1/2"
It weighs 17 lbs. I'm not worried at all for the skids as I leave 1/8" when snow blowing. Good Luck
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #5 of 13 Old 12-23-2014, 03:39 PM
Thanks (Given): 112
Likes (Given): 354
Sounds good, found this piece of steel for free so I thought I would start small. Just the wet snow at the End of Driveway El Toro wants to run up on, a pain to lift up on blower to keep the cutting edge down.
Hanky is online now
post #6 of 13 Old 12-23-2014, 04:44 PM
Likes (Received): 1383
MAZEL TOV there Zippy.
post #7 of 13 Old 12-24-2014, 07:53 AM
Thanks (Given): 51
Thanks (Received): 36
Likes (Received): 63
I'd recommend you try more weight. I used 25 pounds on the front of my 8hp Noma 27 inch, equipped with snow cab. It was perfect. Without the cab I'd go with 20. I placed mine above the front edge so as not to impede intake height.
It makes a huge difference with dense, heavy snow particularly EOD plow banks. But not just plow banks, it makes the job easier anytime by reducing the machine's tendency to climb.
SnowG is offline
post #8 of 13 Old 12-24-2014, 08:10 AM
Thanks (Given): 112
Likes (Given): 354
Thanks for the tip, just have to wait for the rain to stop and snow to come for a test. Have one more larger piece of steel that will get me 18 or so lbs.
Hanky is online now
post #9 of 13 Old 12-24-2014, 08:34 AM
Thanks (Given): 51
Thumbs up
I recommend you start with the full 18 pounds. The improvement will be more dramatic, and it still won't be enough to make it difficult to lift the front when you want to pivot turn.
Don't forget, when you want to lift the front you're pushing down, with body weight and gravity on your side, and it's only for the time it takes to make the pivot turn. When you're fighting the machine's climbing, it's for a longer sustained duration and you're using your biceps and shoulders and back to lift the machine's handles.... Having the extra weight up front is much easier on your body.
SnowG is offline
post #10 of 13 Old 12-24-2014, 10:48 PM
Thanks (Given): 112
Likes (Given): 354
SnowG do you have a picture of how you mounted your weight did you paint it to match your Blower??
Hanky is online now
