Toro S620 - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 12-23-2014, 07:31 PM Thread Starter
Toro S620
I came across a free Toro S620 snowblower. It has an electrical outlet as well as a gas tank. I got this machine free as the owner threw it away but it didn't come with a cord. I was wondering if anyone in these forums has a similar model and if they can utilize it without having to have the cord present.
So far, all I've done is empty the fluids in it and replace with fresh oil and gas. BUt have not had any luck starting it.
I'm from Florida, now living in SE PA. This is my first experience with a snowblower.
Thanks much for any advice
airforceone is offline
post #2 of 12 Old 12-23-2014, 07:35 PM
you need to rebuild the carb, the old gas makes the diaphrams stiff
post #3 of 12 Old 12-23-2014, 07:39 PM
Likes (Given): 1887
Likes (Received): 665
hello airforceone, welcome to SBF!! the plug in for the electrical cord just tells you that it has a 120v electric starter, plug an extension cord in a wall socket an in your snowblower and press the start button to utilize it. does yours have a pull cord or is it broken
post #4 of 12 Old 12-23-2014, 09:20 PM
Thanks (Received): 143
Likes (Received): 297
Welcome, and fire away with the questions. I take it that you are reasonably mechanically inclined, as you have came to this far. Chances are the carb rebuild kit, as suggested, and a thorough carb cleaning and you should be set.
There are different thoughts on carb cleaning, chemical and ultra sonic. Both work, and both have their plusses and minuses.
If you are unsure, then by all means ask away. There is plenty of information and experience here.
post #5 of 12 Old 12-23-2014, 09:38 PM Thread Starter
Originally Posted by 43128 View Post
Toro Tecumseh Carb re Build Kit for S200 S620 | eBay
Thank you. Haven't done that in years but this is the perfect time to brush up.
post #6 of 12 Old 12-23-2014, 09:39 PM Thread Starter
Thank you detdrbuzzard. This one has a pull cord and an electric push start.
post #7 of 12 Old 12-23-2014, 09:43 PM Thread Starter
Thank you db9938. Reasonably mechanically inclined is a promotion for me sir but thank you.
I was about to throw it away but something told me to log in here and start asking questions. It appears a good ol carb rebuild is on the calendar. I'll do a little research in the next few days and if I have any questions will make sure to post them here but hopefully will just be letting you know in a few days that I got it started.
Thanks much
post #8 of 12 Old 12-23-2014, 10:29 PM
Thanks much
Hey, we're here for ya!
post #9 of 12 Old 12-24-2014, 10:20 AM
Thanks (Given): 276
Thanks (Received): 330
Likes (Given): 3356
Likes (Received): 679
post #10 of 12 Old 12-24-2014, 10:38 AM
S620
Toro instructions for using the electric start feature: Crank engine for 5 seconds then let starter rest for 5 sec. do this cycle for up to 40sec. then let starter cool off for 40 minutes. and repeat until engine runs. Cranking for longer intervals will cause a starter motor to have a melt down. If excessive cranking is needed take the snowblower to dealer for service.
33006 is offline
