Toro 521 (38052) Bogs Down / Won't Push Snow - Snowblower Forum : Snow Blower Forums
post #1 of 23 Old 01-24-2015, 07:48 AM Thread Starter
Hi everyone, I'm brand new here and I'll introduce myself in the newbie thread soon.
I have a Toro 521 (38052 - unsure what year) that I bought second-hand a couple of years ago. It seems to be having a problem actually pushing snow out the chute. It starts off okay, but then seems to bog down and get stuck very easily, even with very light snow.
When there is no snow or very little snow in the auger, everything spins splendidly, but as soon as there is a good amount of snow in there, the auger stops spinning.
I recently had to replace the pulley key and set screws on the pulley, and while I was at it I greased the auger gear box with Mag-1 grease. I've checked the belt and there are no problems there, and after splitting the snowblower apart, I'm able to turn the pulley wheel with absolutely no problem, and the auger blades rotate with the greatest of ease when turning the pulley wheel.
I did notice there seems to be a lot of rust down inside the chamber where the impeller (not sure if that's the right term - the thing that pushes the snow out the chute) is, so I don't know if that's a culprit here.
Thanks for any and all help, this site has been hugely helpful for me so far.
lo2e is offline
post #2 of 23 Old 01-24-2015, 08:01 AM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
Welcome to the Toro Lair of SBF lo2e!!!
Do you have the serial number (next to the model) from your machine? We can get the year from that.
A few things to check...
  • are you using snowblower belts and not automotive belts?
  • are the belts & pulleys free from oil/grease?
  • belt tension
  • Is the engine bogging down? If so, you may have weak compression (valves, bad head gasket) and/or carb (settings, dirty) and/or governor issues.
  • Look into installing impeller kits...a 521 shouldn't be clogging like this...so remedy the issue & an impeller kit will make things much better!
I'm sure other members will swing by and provide their wisdom as well!!!
('87 Toro 38150 826)
post #3 of 23 Old 01-24-2015, 08:18 AM
Likes (Given): 1878
Likes (Received): 661
hello lo2e, welcome to SBF!! so is the engine bogging down or just the auger
post #4 of 23 Old 01-24-2015, 08:27 AM Thread Starter
Thanks, classiccat - responses to your questions, in order:
Serial 6010406
Yes, snowblower belts from the Toro dealer (replaced last year)
I don't happen to see any oil/grease on the belt or pulley
The belt seems to be tight when I press the auger handle, the idler pulley seems to be functioning properly
The engine doesn't seem to be bogging down at all, and I replaced the carb last year (thank goodness for YouTube! )
Just googled "impeller kit" - definitely will try to get one and install it as soon as I can diagnose the current problem!
detdrbuzzard, it is just the auger bogging down, no apparent problems with the engine itself.
  • belt tension
lo2e is offline
post #5 of 23 Old 01-24-2015, 08:41 AM
Zavie's Avatar
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 571
Likes (Received): 270
lo2e, I had a similar problem on my 524, I adjusted my auger belt on my 524 so that
when the auger drive is disengaged the auger very slowly rotated. It moved the snow really good.
After I was satisfied with the way it was throwing I backed off the adjustment just enough so the auger does not rotate when disengaged. Works great now.
Welcome to the forum and best of luck with your 521.
Zavie is offline
post #6 of 23 Old 01-24-2015, 08:41 AM
Thanks (Given): 231
Likes (Given): 2041
I believe you have a 1986 model.
post #7 of 23 Old 01-24-2015, 08:43 AM
Likes (Given): 1878
sounds like an '86 toro 521 by the number you gave, there is an owners manual on the toro website for your machine, the download is free
post #8 of 23 Old 01-24-2015, 08:58 AM Thread Starter
Wow, thanks for all the answers so far.
detdrbuzzard, I just downloaded the manual, thanks for that tip.
Zavie, it looks like from the manual that adjusting the belt involves the clevis linkage near where the handles attach to the rest of the snowblower? Or is there somewhere near the belt itself where I can adjust?
Thanks again all - this site is wonderful.
Edit to add: I forgot to mention that my auger currently does spin very slowly when the auger drive is disengaged, same as what Zavie described at first. It has done that as long as I've had it.
lo2e is offline
post #9 of 23 Old 01-24-2015, 09:44 AM
GustoGuy's Avatar
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
Glazed belts can cause much slipping and some times taking off the belts an cleaning the pulleys with brake cleaner and replacing the belts will restore the grip again once you engage the auger. Likewise check the tension on the tensioner for the belt if it is too loose it will allow slipping. Belt should be snug when auger drive is engaged.
GustoGuy is offline
post #10 of 23 Old 01-24-2015, 10:08 AM
Thanks (Given): 172
Likes (Given): 450
Likes (Received): 1027
Welcome from the Keystone state.
Stick around here for a whole and your blower problems will disappear. Lots of good help here.
