1980 Toro 826 38150 needs tire chains - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 02-05-2015, 10:08 AM Thread Starter
Hi,
new guy needs options. just got this snow blower first thing i think it needs is chains.
it seems however that the OE sets are discontinued though some suppliers list untitled or explained "options" and call us prompts.
any one know for sure what's out there, i don't much like half ok setups.
thanks,
steve
DetonatorTuning is offline
post #2 of 14 Old 02-05-2015, 10:35 AM
Likes (Received): 1383
the aftermarket chains are pretty much the same as the OE chains. have you perused E-BAY for the OE stuff??????????????
post #3 of 14 Old 02-05-2015, 11:44 AM
or try this place tirechainsareus.com ..
post #4 of 14 Old 02-05-2015, 02:00 PM Thread Starter
thanks for both replies, i'm in the hunt.
post #5 of 14 Old 02-05-2015, 03:37 PM
Thanks (Given): 178
Likes (Given): 466
Likes (Received): 1045
Hello and welcome. You want to go to Tire Chains by TireChains.com
Now, tell me why you need chains? Are you on a hill? Are you blowimg imsane amounts of hard packed icey/snow? If the conditions aren't there and you're spinning tires you're probably forcing the machine. Adjust your speed to the conditions and let the machine do the work.
post #6 of 14 Old 02-05-2015, 04:20 PM
Likes (Received): 26
I don't have any conditions described above where I live, but the chains definitely make a difference in some situations. I find that the tire rubber hardens quickly in the cold and slips on compacted snow like crazy (without chains). It's like trying to have the blower move on an oil patch sometimes - the pile of snow in front of the auger is enough to have it spinning wheels and not moving. Not always, but sometimes.
All in all, the OP is probably wise to look for chains. When I looked for a set for my parents' new Ariens, there were many places that sold them, including eBay. You need the exact dimensions of your wheels though. Good luck!
762mm is offline
post #7 of 14 Old 02-05-2015, 08:25 PM Thread Starter
Hi Joe,
thanks for both t he reply and link.
you got me on the bunch of icey snow too.
my city street department plows multiple full lane passes of everything in the street onto the walk in front of my house.
the latest was 12 to 30 inches of semi compact dampish stuff that sat for 3 days before i got to it during which time it went to sub zero and turned the bottom to fine crystal dust.
even low range of speed was to much, spent lot of time just letting the auger chew then advancing alittle bit.
i did however get thru in one pass and am still very impressed with the machine.
we get alot of lake effect so i think i'll go ahead with the chains, i like the look of those after market skids and the impeller mod too.
steve
post #8 of 14 Old 02-05-2015, 10:17 PM
Thanks (Given): 178
Likes (Given): 466
Yep. I'd say chains would be a help in your case. I've ben spoiled and sometimes I forget hiw it can be. I was an educator and on days w/snow I didn't have to go to work, and could remove snow at my leisure. Perfectly flat and not a huge amount of EOD problems.
Tirechains.come is pretty good. Just make sure you have the exact size stated.'
post #9 of 14 Old 02-06-2015, 06:29 PM Thread Starter
well nuts, i think i have found a problem and an explanation of some of the traction issue.
seems one of the tires has about a 3" long check and split longwise in the outer side wall and is pretty much done.
i'm very sure i didn't catch it on anything, nothing that could do that along my walk or drive.
probably didn't notice when i was looking it over.
So.......who sells tires at the best bargain ?
thanks,
steve
post #10 of 14 Old 02-06-2015, 06:43 PM
It is common for older tires to be cracked and dry rotted. A lot of them had tubes in them so they still hold air fine. Last time I looked Summit Racing had good deals on tires. Someone else recently posted the same thing on here. Snow Hog and X-Track are the two popular styles with the X-Tracks being preferred because the Snow Hogs can be a bit bouncy.
