Toro PowerShift 1232 Auger gear oil - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 02-07-2015, 10:00 PM Thread Starter
Question Toro PowerShift 1232 Auger gear oil
searched in google and a lot of the same unanswered questions came up... couldnt find any info here, maybe its buried?
can you guys help me with changing the gear oil on my 1232?
the unit works great (hand me down from Dad) but it prob hasnt been looked after in ages.
changing the oil and spark plug will be easy enough but the specs for the auger are 85w-95 GL-5 or 6, non synthetic... that oil weight is almost impossible to find. this thing cant use more than a cup? should i even bother? what gear oil should i put in this?
Thanks guys,
Kevin
Toro 1232 Power Shift, 38590 (1998 i think)
B737 is offline
post #2 of 12 Old 02-08-2015, 12:51 AM
Likes (Received): 26
762mm is offline
Thanks B737 thanked for this post
post #3 of 12 Old 02-08-2015, 03:00 AM
Thanks (Given): 30
Thanks (Received): 40
85w90 gear oil
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #4 of 12 Old 02-08-2015, 08:05 AM Thread Starter
85-90 it is then, easy enough, thanks guys for your help
B737 is offline
post #5 of 12 Old 02-08-2015, 09:54 AM
Likes (Received): 1383
80/90 weight non synthetic. the seals will not hold the sin stuff.
post #6 of 12 Old 02-08-2015, 01:40 PM Thread Starter
this okay?
im pretty sure its non-synthetic
Liqui Moly (1404) 85W-90 GL-5 High Pressure Gear Oil - 500 ml
B737 is offline
post #7 of 12 Old 02-08-2015, 01:42 PM
Originally Posted by B737 View Post
this okay?
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
yeah that will work. auto stores are cheaper just throwing that 1 out there.
post #8 of 12 Old 02-08-2015, 01:46 PM Thread Starter
thanks gents
got the motor oil changed out today, was a little tricky getting the level just right. will change the spark plug, and auger oil this week. adjusted the carb (i think) it seems to be happier. old oil came out pretty ugly.
B737 is offline
post #9 of 12 Old 02-08-2015, 09:01 PM
Best way to put in the right amount of oil is to stick to what the manual says (fluid volume specs). That's how I did it in mine, both the engine oil and auger gear fluid. Get yourself a funnel with a long flexible spout for future engine oil changes... makes filling a whole lot easier. I got me one for about $10 locally.
For the auger gear fluid, I actually put in a tad more than the specs call for by tilting the blower backwards a bit during fill up. I used axle stands under the auger housing to do that. The tilted back position allows for more oil/fluid to enter without over filling.
A bit more fluid in gears is always a good thing, without over doing it of course (when there's a bit more of it, it stays cleaner longer and also is better at cooling hard working gears). I used a similar trick to fill up the diffs on my trucks for routine maintenance a few years ago.
762mm is offline
post #10 of 12 Old 02-10-2015, 01:41 PM Thread Starter
thanks guys for the help here.
i took the plug out of the gear box, nothing came out.. once i tipped the machine up on its nose fluid emptied. looked thick and gnarly.
the liqui moly container was cool cause it has a built in fill tube that fits the opening so no funnel needed. i rested the machine skids on a 2x4 which allowed for a touch more fluid as posted earlier. ran the machine with its new spark plug, adjusted carb, new fluids and it doesnt seem too different but maybe a little smoother. ran the auger for 20 minutes or so, no signs of leaks or seeps (crossing fingers).
foolishly cleaned the exhaust manifold and muffler with sand paper and painted it with high temp 1200 degree brake caliper paint... it boiled off in just a few seconds was worth a shot though lol looked nice for a day
old gear oil on left, not much came out.
B737 is offline
Thanks 762mm, detdrbuzzard thanked for this post
