Tecumseh Carburetor 640052 - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 02-08-2015, 06:00 PM Thread Starter
Having issues with Toro snowblower staying on. I have cleaned the entire carb. It will run fine after cleaning for approx 15mins then eventually stalls. Now having a hard time to start again - only starts if the choke remains on - then will stall after a few mins.
Any thoughts or advice?
Has anyone else had issues with this model - Tecumseh Carburetor 640052
thanks
Toro826 is offline
post #2 of 6 Old 02-08-2015, 06:07 PM
Likes (Given): 1882
Likes (Received): 661
hello toro826, welcome to SBF!! what is the serial number of your machine, post a pic or two of your machine also if you can
post #3 of 6 Old 02-08-2015, 06:11 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
Welcome to the Toro Hangout on SBF!
You have a lean condition...starving for fuel. Blocked bowl vent, bad gas cap (also has a vent), collapsing fuel line, clogged fuel filter are some of the common causes.
Also, how did you clean the carb? Full tear-down & soak?
('87 Toro 38150 826)
post #4 of 6 Old 02-08-2015, 06:31 PM Thread Starter
followed this
Toro826 is offline
post #5 of 6 Old 02-08-2015, 07:55 PM
Thanks (Given): 231
Likes (Given): 2041
That guy's a cowboy! he does a good job explaining the various components.
I personally prefer full disassembly including welch plug removal, soak in a gallon can of carb cleaner, rinse in hot water then blow out all of the passages with compressed air. I dread using aerosol carb cleaner.
With that said, see if loosening the gas cap brings the machine back to life when it starts running rough.
Also is yours an emission / fixed-jet carb? If it is an adjustable jet, have you tried opening the main jet a bit?
post #6 of 6 Old 02-08-2015, 07:59 PM
Thanks (Given): 231
Likes (Given): 2041
oh and +1 on the pics
