Toro 2000 - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 02-10-2015, 12:52 PM Thread Starter
Toro 2000
We have an old Toro it runs well, or did, The last snow storm one pull and it started right up. Then I turned it off about 20 minutes later the city plow covered the apron and sidewalks again so I tried to start the snowblower but it would not start up. It was working great a few minutes before and there was enough gas but it would not work, a few hours later I tried again a few times it almost started up but didn't. Today I tried again and no luck spark plug looks clean. What the **** happened?????
manowar is offline
post #2 of 7 Old 02-10-2015, 04:06 PM
Likes (Given): 1880
Likes (Received): 661
hello manowar, welcome to SBF!! make sure the sparkplug is firing and that gas is flowing
post #3 of 7 Old 02-11-2015, 01:57 PM Thread Starter
I put a new spark plug and gas looks to be flowing best i can tell. When I prime it I can see gas in the little tray. Now with a new plug I pull starter and it starts for a second and dies, pull again same thing happens. What else can be wrong with it?
manowar is offline
post #4 of 7 Old 02-11-2015, 02:03 PM
Likes (Given): 1880
carb could need cleaning after all there years
post #5 of 7 Old 02-11-2015, 04:31 PM Thread Starter
I need to get a spray for that? I never did that before, walk me through it if you have time. It's odd that the first time i used this machine in about 4 years on the first pull it starts and now it won't anymore
Thanks for your help.
manowar is offline
post #6 of 7 Old 02-11-2015, 06:02 PM
Likes (Given): 1880
I would be better if you watched a couple of carb rebuild vids on you tube
post #7 of 7 Old 02-11-2015, 09:45 PM
Likes (Received): 7
Fresh gas is not only excellent fuel but also a pretty potent solvent (old drag racers adage - alcohol is for drinking, gasoline is for washing parts, nitro is for racing). Quite likely that the new (fresh) gas dislodged some crap in the carb.
You can try cranking the mixture screws open and hope the fresh fuel will flush the junk out the adjust back to proper settings. Otherwise - See above referenced YouTube vids and clean out your carb.
2015 Toro Power Max HD 826 OXE
1980 Toro 8-24 (5-24 re-powered with 8hp Briggs) - SOLD
1971 Toro 8-26
1963 Panzer T-70B with snow plow
2015 Chevy 2500 with 8' Fisher X-Blade
I hate shovels.
wfd44 is offline
