1028LXE help advice - Snowblower Forum : Snow Blower Forums
post #1 of 22 Old 02-12-2015, 09:07 AM Thread Starter
1028LXE help advice
Delete
PK778 is offline
post #2 of 22 Old 02-12-2015, 09:14 AM
If you have a 1 inch gap you definitely have the wrong impeller and possibly the whole gearbox.
You have tried the rubber strips? You might need metal plate under the rubber to support it with that big of a gap. Run the metal to like 1/8" from the edge and then the rubber all the way to the edge as close as possible.
post #3 of 22 Old 02-12-2015, 09:20 AM Thread Starter
Delete
PK778 is offline
post #4 of 22 Old 02-12-2015, 04:06 PM
Likes (Received): 1383
Originally Posted by PK778 View Post
I used a thick mudflap and metal strapping, problem is it was hitting on the side where the cut out for the powermax auger area is, the metal is overlapped there so once trimmed down it doesn't clean the drum well. I meant to mention this in the original post, there's a lot of clearance behind the impeller drum to the back of the bucket housing. I can put my fingers behind it, when off of course. it fills with snow. It's odd. When I replaced the bearing, which was beyond toast, I didn't notice anything out of place, but I didn't have to remove the whole auger either, i could reach around and barely touch the carriage bolts with my fingers to hold them in place, actually one fell out and i was able to put it back in, there's enough clearance. Should have taking a few pictures
Is it possible it was bolted to the auger shaft in the wrong place, is there adjustments there?
post some pics so I can have a looksee in there.
post #5 of 22 Old 02-12-2015, 05:56 PM Thread Starter
Delete
PK778 is offline
post #6 of 22 Old 02-13-2015, 06:39 AM Thread Starter
Delete
PK778 is offline
post #7 of 22 Old 02-13-2015, 07:55 AM
I am going to need better pics. some need to be further out. and try to dry everything up in there. I can't see anything with those. take a vid of the clutch problem. even inside of the bowels of that machine.
post #8 of 22 Old 02-13-2015, 08:21 AM Thread Starter
Delete
PK778 is offline
post #9 of 22 Old 02-13-2015, 08:25 AM
I'll try to clear the snow out. It's cold can't get it to melt even on the garage
GOT a hair dryer or heat gun.??????
post #10 of 22 Old 02-13-2015, 10:17 AM Thread Starter
Delete
PK778 is offline
