Power Shift Model 38560 "No movement any Gear" - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 02-13-2015, 08:56 AM Thread Starter
Hello, Machine will not move in any Gear. Belts are brand new, shift appears to be working, Roller Chain on and o.k. This machine has a transmission case. Is there an adjustment? Could it be an easy fix? Thanks for the help on this. Serial #230000741, Model #38560.
BoscoMurphy is offline
post #2 of 9 Old 02-13-2015, 09:31 AM
Likes (Received): 1383
if it is a POWERSHIFT I can fix it. but I will need a vid of the machine. to become 1 with it. and I am sure you are a long way from the frozen tundra. ALOHA!!!!!!!!!!!!!!
post #3 of 9 Old 02-13-2015, 09:55 AM
Thanks (Given): 276
Thanks (Received): 330
Likes (Given): 3351
Likes (Received): 679
Hello and welcome to the forum BoscoMurphy. I know very little about Powershifts so Powershift93 is the man to help. I do have a link to the manual in case you need to make adjustments based on his forthcoming advise.
Tosnowps[1] Copy
post #4 of 9 Old 02-13-2015, 09:56 AM Thread Starter
Re-Powershift
Hi Power Shift, I stated the model number & ser. number in my post
post #5 of 9 Old 02-13-2015, 10:17 AM Thread Starter
Thanks for the Link to the Manual Grunt. I just buzzed through it and it might be the tension springs that are up underneath. I won't know until I get it apart.
post #6 of 9 Old 02-13-2015, 10:23 AM
Tosnowps[1] Copy
I have said this a million times over. BROTHER GRUNT is the man that always has the master plan in hand.
post #7 of 9 Old 02-13-2015, 10:46 AM
Thanks (Given): 276
Likes (Given): 3351
Aw shucks, just trying to help. With your advise, he will do just fine.
post #8 of 9 Old 02-13-2015, 06:15 PM
Thanks (Given): 30
Thanks (Received): 40
A quick test to see if the belt has enough tension : With engine OFF and belt cover off, pull the spark plug wire off, trans in N , squeeze traction handle, and pull the recoil slowly. If the shaft/pulley turns and the belt turns WITH IT, it has tension , if the shaft / pulley turns and the belt slips, not enough tension. Hope this helps.
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #9 of 9 Old 02-13-2015, 06:22 PM
Another thing to check out. is the tab that bolts to the trans from the shifter down below. check to see that is not bent, broken or in some other state of disarray.
